QUOTE (seigfredm @ Jul 24 2008, 04:23 AM)
I just bought a wheel and tire package, everything fits but when I got two or more passenger my rear fender rubs on bumps and humps.
I am in the process of fabricating a fender roller and is almost done but a friend of mine told me there is something like a rubber insert that you put on the coil so that it can only go down so much on bumps and load therefore not letting the tire to hit the fender.
Have you guys used this if this actually is being sold in a local autozone or kragens?
Just looking for options.
Thanks
You must have rims with insufficient offset, I have the same size tires on 7.5" rims with a 48mm offset and am on Mazdaspeed springs. I have no rubbing issues.
Putting a spring rubber in won't eliminate the rubbing, at best it will make it happen less. It also turns that coil in your spring into a solid block and increases spring rate and ride harshness. A poor trade-off for still not solving the problem.
Since you already have the rims your only other recourse is what you're going to do eventually which is roll the rear fenders.
