I just posted in the "Newbie" section and wanted to share my rim experiment with you guys to get your input.
My current set-up:
ZINIK SABINI (Z9) 18” x 7.5” + 42MM OFFSET / 114.3 x 5 PCD (27LBS EA) **no rubbing**
FALKEN ZIEX ZE 512 225 / 40ZR 18 92W M+S
Dropped on 2" Eibach Springs
I came up on these wheels for dirt cheap and couldn't resist the deal. I was never a huge fan of the black/chrome lip look but at the time could not find any all black rims that I liked. I love blacked out cars.
I saw a guy on here go all black on a set of OEM RX8 rims and I really liked the outcome. Trying to keep things simple and cheap I decided to do the same on my stock 06 grand touring 18's.
Based off of input I gathered, here are the specs for the OEM Y Spoke 18's:
MAZDA 6S OEM Y-SPOKE 18” x 7 +55MM OFFSET / 114.3 x 5 PCD (27LBS EA)
CENTER BORE 67.1MM
I paid $306 to have all 4 stockers powdercoated black at Electro Tech Powdercoating in San Marcos CA.
I bought some 15mm spacers to kick them out to +44mm (incorporating going from 7.5" to 7" in wheel width).
The spacers are hub centric with their own studs (not the disc type spacers). I've been running the same style spacers on my 440HP FD for the past 5 years w/ no problems.
I want to run the 225/40 tires on the black stockers but am not sure how they will fit. Most fitment charts I see say that 215/45 is max for a 7" rim. I know that the 225/40's will fit but I was wandering if anyone else was running the same or a similar set-up on a 7" wheel?
Last thing is lug nuts. I don't want to use the stock chrome lug nuts and I have been looking for black ones. Most sets that I see say they will not work with OEM rims because they are tapered. Does anyone know where I can come up on some black close ended lugs that will work with my OEM rims?
As soon as I figure out the tire and lug nut situation these are going on the car and I will put some pics up.
Click to view attachment
