Sound Deadening for 3rd Gen 2016 6's - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 6Likes
post #1 of 17 (permalink) Old 06-17-2016, 01:23 AM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
Hello Everyone,
Time I contribute a bit: Today I started with sound deadening my 2016 6 Touring.
My plan is to do all 4 doors than move to the wheel wells and if I still have some stuff remaining - the Trunk area. I am going to skip all the flooring (maybe later).
I am using "apparently" Dynamat that didn't pass the QC check from Deimos Deals (ebay).
I ordered 10sqft and it came in 6 panels about 2x1ft each.
I finished the driver door today and man what a difference in just opening and closing the door. I used two panels for the door and did all inside the door as well around the speaker and some of the other exposed metal parts.
ID:	186601   Click image for larger version
ID:	186609   Click image for larger version
ID:	186617   Click image for larger version
flyandi is offline
post #2 of 17 (permalink) Old 06-17-2016, 04:53 AM
Donkey Grundle's Avatar
Quoted: 435 Post(s)
Groans: 22
That speaker is going to seem loud as hell until you get the other doors done! I'm excited to see what results you get from the wheel Wells.
Sent from my HTC6525LVW using Tapatalk
J1MB3AM likes this.
Donkey Grundle is offline
post #3 of 17 (permalink) Old 06-17-2016, 07:19 AM
my95tsi's Avatar
Quoted: 260 Post(s)
I thought you're supposed to put that stuff on the outside part not the inside? Any video I've ever watched regarding installation was with it on the outside part.
my95tsi is offline
post #4 of 17 (permalink) Old 06-17-2016, 10:22 AM
Quoted: 7 Post(s)
I am also curious about applying it to the inside of the door panel vs against the outside sheet metal. As far as acoustics go I would imagine doing it the way flyandi did, you are preventing the road noise from entering the air space between the outside sheet metal and inner door panel. You've got the added step of removing the inner plastic piece, but the ease of installation seems to be worth it. Doing larger strips vs a ton of small cuts while avoiding all the clip holes. Seems like a no brainer, but I could be wrong.
J1MB3AM is offline
post #5 of 17 (permalink) Old 06-17-2016, 12:10 PM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
Don't know the advantages/disadvantages inside VS outside but looking at the plastic panel it would be very difficult to attach the mat to it. It's a freaking moon crater landscape.
Also the plastic panel is just screwed in and I know the guys doing it on the outside are trying to create an "enclosure" for the sub speaker in the door - but I also did some generous pieces around the speaker as well.
J1MB3AM likes this.
flyandi is offline
post #6 of 17 (permalink) Old 06-17-2016, 02:37 PM
my95tsi's Avatar
Quoted: 260 Post(s)
I didn't realize our cars did not have the plastic liner in the door. I've never seen that.
my95tsi is offline
post #7 of 17 (permalink) Old 06-17-2016, 02:42 PM
my95tsi's Avatar
Quoted: 260 Post(s)
I was following this thread previously where the dynamat was installed on the outside.
http://forum.mazda6club.com/3rd-gen/...ise-issue.html
my95tsi is offline
post #8 of 17 (permalink) Old 06-20-2016, 12:42 AM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
So I finished the doors and trunk area.
Didn't had time for the wheel wells this weekend - way to hot here.
J1MB3AM likes this.
flyandi is offline
post #9 of 17 (permalink) Old 06-20-2016, 01:53 AM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
So I am thinking as a transition layer between the mat and the wheel wells I think I am going to get Home Depot Carpet Padding .. it's synthetic fiber and you get it for $0.50 per sqft ..
flyandi is offline
post #10 of 17 (permalink) Old 06-21-2016, 02:21 PM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
I finally started the wheel wells last night - .. well kind of.
Turns out that on my 2016 6 there is already a thick layer of panels + liquid sound deadening inside the wheel wells. The knock test confirmed it - it's barely hearable in the cabin - so the road noises are not coming from that direction into the cabin.
Now I wasted one big strip of material since I already put on the bare metal :\ ..
Oh this is the front btw - I will check the rear tonight and see if there is a similar picture there.
ID:	186825   Click image for larger version
ID:	186833   Click image for larger version
flyandi is offline
