Sound Deadening for 3rd Gen 2016 6's - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 6Likes
post #11 of 17 (permalink) Old 06-21-2016, 05:16 PM
Donkey Grundle's Avatar
Quoted: 435 Post(s)
Groans: 22
The guy that did the wheel wells on his 3 reported that the dynamat didn't do much, but adding a foam made a significant reduction in noise.
Sound deadening - Page 6 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
Donkey Grundle is offline
post #12 of 17 (permalink) Old 06-22-2016, 12:14 AM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
The issue is that I don't know where to mount the foam .. there is only a very small space in the mud guard area that isn't part of the water drain channel system.
I am pretty sure that once it rained or you wash your car that stuff is soaked.
flyandi is offline
post #13 of 17 (permalink) Old 12-04-2016, 05:27 PM
Quoted: 6 Post(s)
Do you think a product like this would work well?
https://www.doitbest.com/products/10...sqRBoCFWLw_wcB
csiaudio is offline
post #14 of 17 (permalink) Old 12-04-2016, 11:23 PM Thread Starter
flyandi's Avatar
Quoted: 258 Post(s)
No idea but Amazon sells the stuff pretty cheap. I am using the G-Matt products.
flyandi is offline
post #15 of 17 (permalink) Old 12-15-2016, 10:32 PM
Quoted: 9 Post(s)
Depends, sometimes the peal and seal stuff won't last long term. Depends on the quality and thickness like with all things. If you go that route buy something you can see in person.
03 Mazda 6s ATX - Lapis Blue
cncaliguy is offline
post #16 of 17 (permalink) Old 12-16-2016, 01:36 AM
Quoted: 7 Post(s)
i used peel n seal on my speed worked solid. It melted when it got hot in the trunk give it 3.5 outta 5
[/IMG]
kashimus is offline
post #17 of 17 (permalink) Old 12-30-2017, 02:04 PM
knsaber's Avatar
Quoted: 31 Post(s)
I see no purpose of sound deadening plastic. When I close my door I hear the reverb of the sheet metal. Thatís where the vibration sounds probably come from and where you want to deaden it. Iíve never seen a DIY that applied mats to plastic, only the bare sheet metal.
2016 Mazda6 Grand Touring w/Tech Pkg
knsaber is offline
