Old 10-15-2009, 02:15 AM   #1 (permalink)
Hey guys, I searched for it on here for a bit and didnt find an answer. I want to change my stock grey shift know and boot with black leather. Can some one tell me how to take it off? I also want to change the hand break to black leather..
Any help would be appreciated.
Benzeen is offline   Reply With Quote
Old 10-15-2009, 10:15 AM   #2 (permalink)
jd42's Avatar
QUOTE (Benzeen @ Oct 15 2009, 02:15 AM)
Can some one tell me how to take it off?[/b]
This writeup from Mazda6Tech should help you get the center console apart:
http://www.4shared.com/file/105164933/e72d...er_console.html
Once you remove the panel around the shifter, you should be able to unfasten the shift boot from underneath.
Old 10-15-2009, 11:22 AM   #3 (permalink)
Great. Thanks alot.
