Old 09-30-2009, 03:24 PM   #1 (permalink)
Dash lights not coming on until I turn on side/headlights?? whats happened here?
Thanks
mrbiccies is offline   Reply With Quote
Old 10-01-2009, 01:38 AM   #2 (permalink)
garrett27's Avatar
nothing? when its light out you shouldn't need them? try the brightness wheel to the left of the steering wheel, about knee level. that's all I got.
Glacial Silver 2006 6I ATX
The 6
garrett27 is offline   Reply With Quote
Old 10-01-2009, 12:18 PM   #3 (permalink)
QUOTE (garrett27 @ Sep 30 2009, 09:38 PM)
nothing? when its light out you shouldn't need them? try the brightness wheel to the left of the steering wheel, about knee level. that's all I got.[/b]
The dash lights used to come on when I turned on the ignition, then dim if I turned the side/headlights on...........Tried the brightness wheel, works when the headlights are on, but nothing without the headlights on. Are there seperate dash lights for when the headlights are on or off?
Old 10-01-2009, 02:26 PM   #4 (permalink)
garrett27's Avatar
dont think so. check your fuses?
The 6
Old 10-01-2009, 02:28 PM   #5 (permalink)
I can't ever remember my dash lights on when the headlights were not.
lacuna is offline   Reply With Quote
Old 10-01-2009, 08:13 PM   #6 (permalink)
67igor1's Avatar
hi, there are 2 positions:
1. when you tourn on an ignition key: comes on a small LCD screen (milage and odometer):
[attachment=43954:P15_07_0...3.01_02_.JPG]
2. when you tourn on the lights... comes backlighting (speedometer, fuel, ....) and dimm the small LCD screen.... you can use the brightness wheel to calibrate it:
[attachment=43953:zdegary_1.jpg]
There are the same LEDs but "+" are different.... first comes from ignition, second from backlighting
M6 TS2 2005 141KM saloon
Backlighting:
http://forum.mazda6club.com/index.php?showtopic=117157
67igor1 is offline   Reply With Quote
Old 10-01-2009, 08:24 PM   #7 (permalink)
StlMazda6's Avatar
67igor1,
Did you custom install the green lighting yourself or is that standard in the UK?
StlMazda6 is offline   Reply With Quote
Old 10-01-2009, 08:35 PM   #8 (permalink)
67igor1's Avatar
StlMazda6 Sorry ... Mazda gives the same backlighting everywhere...
I did it by myself
Backlighting:
Old 10-02-2009, 01:57 PM   #9 (permalink)
WOW.....must be getting confused with the wife's car then! I was sure the backlights came on when you turned on the ignition....had the car for over 6 years now too, must be going round the twist! thanks for your help guys.
Old 10-03-2009, 01:15 PM   #10 (permalink)
No. You're right. The gauge cluster lights come on when the ignition is on.
JDisturbed is offline   Reply With Quote
