i have been experimenting with real CF fabric from Euro Dyne and here are some of the pieces i have gotten to wrap
![]() ![]() ![]() ![]() ![]() ![]() ![]() Unfinished Metra kit (will be done tomorrow) ![]() ![]()
2004 Onyx Black 6s Sport MTX Performance:-Injen CAI, CP-E Engine Mount, SM Oil Catch Can, Racing Beat Rear Sway Bar w/ AWR Endlinks, Fluidampr Underdrive Crank Pulley(1 of 45), Custom Exhaust, Neo 75w90 HD Trans Fluid, Corksport SS Clutch Line, TB Coolant Bypass Appearance:Apexcone 55W 8000k HIDs in lows, Apexcone 35 watt HIDs in fogs, PIAA Extreme Whites in Highs, Blacked Out Side Markers, Painted Engine Cover, Viper 5002 Security System, 5% Tint, 2006 Tail Lights, OEM Sport Grille, NRG Hood Dampers, De-badged, VG Shark Fin, Red LED Map Lights, Red accent lights, Enkei GTC 01 Hyper Black Rims wrapped with Yokohama S.Drive Tires, Alpine IVA-D106 In-Dash Future mods:Sniper Tuning, NGK Iridium IX Spark Plugs, Stacker 8, Sniper Coils, MSDS Headers, AWR Passenger and Driver Mounts |
That is beautiful. If I was doing a custom system that would be my first choice for a finish.
2006 Black Cherry Mica Speed6 VIN #964 AEM Intake, ETS TMIC 3.5" core, custom dual outlet 3" cat back (quiet) Protege Garage CDFP, SU Rear MM RPM Sport Springs, ALT Sonix in black Darkstar Boost Tubes, Darkstar Turbo inlet pipe. CPE Standback PNP (@CP-E for Diagnostics.) Car LED Tail Lights. VG Sharkfin Antenna. |
thats good work bro, ive heard that stuff is hard to work with and you lines match up very well. keep the pics comming
Def looks badass
post pics when its back in the car
2006 Liquid Platinum Mazdaspeed 6 GT Shark fin antenna, led clear corners, smoked rear led reflectors, PIAA Extreme White Highs/fogs, CPE CAI, Powder coated stock MS6 Wheels, TWM Stage 2 STS, CPE Catted DP, Auto Exe TMIC & Cobb Inlet Pipe. |
just a little update with the metra kit
#7 (permalink) | |
QUOTE (ZOOMZOOM43 @ Jun 10 2009, 03:34 PM)
#9 (permalink) |
That looks awsome. What thickness is it and where did you get it. The finish looks a little dull, but maybe its just the pics. Are you going to maybe put a clearcoat on it?
06 MazdaSpeed6 Protege Garage Block with Arias rods & Pauter 8.8:1 pistons | Spin on filter conversion and sandwich plate | High flow cam driven fuel pump| ARP Studs | NGK 1 step colder Plugs | HKS Twin Ignition Amplifier | Custom Factory Exhaust Manifold with 44mm Tial Wastegate | ATP GT3071R Turbo and downpipe | Custom Borla 3" exhaust | CP-E front mount Intercooler with HKS Recic. BOV | 3" ATP short ram intake with Cobb filter | Diehard battery and CP-E Tray with NRG Voltage Stabilizer | CP-E Wishbone rear engine mount | Sped Stage 2 Clutch kit | Eibach Pro Springs | 5Zigen SC3000 powdercoated Black | 3 gauge pod & gauges | TWM Short Shifter with 600 gram Desert Eagle shift knob | CP-E Standback | Full Control Flash | Fuel Cut Fix | Escort SR7 RAdar System |
