Old 09-21-2007, 10:42 AM   #1 (permalink)
How do I remove the door panel on the passenger side? my mirrior is clunking noise when I close it and I want to inspect to see what's going on.
Thanks,
CU2003 is offline   Reply With Quote
Old 09-21-2007, 11:08 AM   #2 (permalink)
Iluv2zmzm's Avatar
Door panel removal
if you have the bose remove the tweeter first, just pull it straight out....
Cardomain Page
6club Garage
Iluv2zmzm is offline   Reply With Quote
Old 09-21-2007, 07:31 PM   #3 (permalink)
Another link:
http://forum.mazda6club.com/index.php?showtopic=29821
Which is also a sticky
2004 Lapis Blue 6s ATX Sedan
fxtrt is offline   Reply With Quote
Old 02-12-2009, 04:30 PM   #4 (permalink)
Hmm.. I unscrewed all 3 screws and pulled out the inner handle part and still can't seem to nudge the door off. I tried using a butter knife to free the door panel and still couldn't get any part of it to budge. The reason for needing my door panel off is that my courtesy light socket fell in and i can't get it back in place good enough for me to put a new bulb in it. Any suggestions?
'05 Steel Grey Mazda 6s gt
Deathreign is offline   Reply With Quote
Old 02-12-2009, 05:00 PM   #5 (permalink)
jbinx's Avatar
QUOTE (JDmazda6 @ Feb 12 2009, 03:30 PM)
Hmm.. I unscrewed all 3 screws and pulled out the inner handle part and still can't seem to nudge the door off. I tried using a butter knife to free the door panel and still couldn't get any part of it to budge. The reason for needing my door panel off is that my courtesy light socket fell in and i can't get it back in place good enough for me to put a new bulb in it. Any suggestions?[/b]
there a plugs/clips all around the door panel. if you start at the bottom edge(where the courtesy light is) and pry it up, you'll see one of the clips(its white). i used my fingers and worked ok. you have to pull hard to get it out, then the rest will pull out easier one by one. be careful to not pull too hard, cuz there are some wire harnesses for the door locks, window buttons, etc that need to be unplugged before you can't take the panel off. you then have to lift the panel upwards in order to get it out of the window glass channel
HID's</span> 35w <span style="color:#4169E1">5000K - clear side markers - smoked rear reflectors
- '03-'05 cupholders/shifter console painted black - 2 white LED's in the cupholders with on/off switch
- footwell leds - badgeless grill - auxmod basic
- 18x8 Rota P1 wheels w/Kumho ecsta SPT 225/40/18 tires
My Garage
jbinx is offline   Reply With Quote
Old 02-12-2009, 05:35 PM   #6 (permalink)
QUOTE (jbinx @ Feb 12 2009, 05:00 PM)
there a plugs/clips all around the door panel. if you start at the bottom edge(where the courtesy light is) and pry it up, you'll see one of the clips(its white). i used my fingers and worked ok. you have to pull hard to get it out, then the rest will pull out easier one by one. be careful to not pull too hard, cuz there are some wire harnesses for the door locks, window buttons, etc that need to be unplugged before you can't take the panel off. you then have to lift the panel upwards in order to get it out of the window glass channel[/b]
Thanks! I will try that. Do you think i'll have to actually pull the entire door panel off in order to put the light socket back through the hole so i can put a bulb in it?
Old 02-12-2009, 08:16 PM   #7 (permalink)
silvermazda6s's Avatar
just pull it all off you dont want to risk damaging the plastic by torquing it a funny way. But you might be able to just pop the bottom clips out to get the bulb holder in
2004 Glacier Silver 6s MT
Current Mods
CPE Intake and CPE MAFCI Fix - Painted Tails - Thule Roof Rack - EGR Mod - Taillight Mod - Garage Door Lip Mod - 35W Apexcone HID Kit - Angel Eyes - Debadged and Blacked out Emblems - Autodim Mirror - Hardwired Radar Detector - LED License Plate Lights - Injen Exhaust - CX-7 antenna - Black Painted Calipers - CPE Wishbone Engine Mount, Strut Bar - Titanium Gauge Overlays - LED Footwell Lighting - Flip Key - Stainless Steel Brake Lines - Hawk HPS Pads - Progress Rear Sway Bar - Mazdaspeed Springs - 12in Rockford Fosgate Sub w/600watt amp - Lotek Gauge Pod with Air-Fuel Ratio - Oil Pressure - Oil Temperature
Future Mods:
LED Door Handle Accent Lighting, RX-8 Wheels, Mazdaspeed Short Shifter
silvermazda6s is offline   Reply With Quote
Old 02-12-2009, 08:46 PM   #8 (permalink)
Send a message via AIM to MicaBlackMS6
QUOTE (silvermazda6s @ Feb 12 2009, 08:16 PM)
just pull it all off you dont want to risk damaging the plastic by torquing it a funny way. But you might be able to just pop the bottom clips out to get the bulb holder in[/b]
ugh, I am going to have to do this as well to replace my mirror. I never have any luck with those damn clips, I always manage to break at least one.
Beauville pronounced Booville
<div class='quotetop'>QUOTE (KFC_Or_Bust @ Feb 8 2009, 03:30 AM) <{POST_SNAPBACK}>
...Why do I even waste my time trying to talk sense and realistic thoughts into your guys's heads?
Kingsford? Lol, you guys are like 3 year olds, entertained by the simplest thing.
<div class='quotetop'>QUOTE (G. Seereez @ Feb 8 2009, 04:04 AM) <{POST_SNAPBACK}>
KINGSFORD isn't simple, you are.
MicaBlackMS6 is offline   Reply With Quote
Old 10-10-2009, 10:19 AM   #9 (permalink)
What about the passenger's door panel? where are the screws?
mikiman is offline   Reply With Quote
