DIY: Lowering Stock 2018 Plate Bracket - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
  • 1 Post By Byakuya
  • 1 Post By idrive
  • 1 Post By Byakuya
  • 1 Post By Mz6GreyGhost
post #1 of 8 (permalink) Old 04-23-2018, 07:26 AM Thread Starter
Chazzy J's Avatar
Quoted: 40 Post(s)
Relatively simple here. You'll need the following:
1) Hacksaw (a bench-saw if you really want to make short work of this - haha)
2) Dremel
3) Exact-o-knife or just a razor blade
4) Universal plate mounting bracket (ebay)
5) Hand-held drill and drill bit
6) Mounting screws (self-tapping if you don't have a drill available)
7) The stock 2018 Mazda6 mounting bracket
8) Recommended, but not necessary, front plate surround (in the event you don't get the universal plate bracket on perfectly level, this can help fix that visually)
The reason for doing this: Cosmetically, I think Mazda strikes out on their license plate location. I realize there's laws surrounding minimum height requirements and stuff like that, but other auto manufacturers don't seem to have this problem...haha. Mazda3 is a great case example -- that plate location was dreadful (modified that too with the help of some friends in Thailand.)
The 2018 Mazda6 isn't nearly as bad, but it still seems high to me. It's almost closer to the Mazda emblem at the top of the grille than it is to the bottom lip on the bumpers -- therefore giving it that "too high" appearance.
As my mantra is "It's gotta look OEM" I make sure my mods take on that appearance. In other words, I'm not doing a tow hook plate. It's gotta look stock.
Total Time Needed: Maybe 30 minutes if you're experienced with the tools. But certainly not more than an hour.
Steps:
1) With the license plate removed, but bracket still mounted, take your universal plate and razor blade and score the plate bracket across the top where you'll hacksaw the top off. Pic 1 below shows where I scored the top and hacksaw'd it.
2) Remove the plate bracket and hacksaw on the score line.
3) Re-attach the plate bracket once done, line up your universal bracket, and drill the desired number of mounting points (I did 2 - doesn't have to be crazy). Install the mounting screws/hardware. Reference pic 2.
4) Reference back to pic 1. You see the top of the hacksawed line? It's unclean and sharp on the rear side of the plate bracket. This is where a Dremel is needed. Detach your plate bracket again and Dremel those sharp edges down. Reference pic 3 for finished job. (Please wear some sort of eye-protection when using a Dremel...enough said)
5) Install plate bracket, universal plate bracket, and license plate (include surround if desired). Mission accomplished.
Reference pic 4, 5, and 6 for completed job. Note that you can now see the full grille and the front end just looks overall cleaner (IMO).
Enjoy guys. We will dub this, "The Chazzy Mod" haha. jk. Share the love guys. We're all Mazda fanatics.
ID:	218682   Click image for larger version
ID:	218690   Click image for larger version
ID:	218698   Click image for larger version
ID:	218706   Click image for larger version
Chazzy J is offline
The Following 3 Users Say Thank You to Chazzy J For This Useful Post:
bleevit (04-25-2018), daddyd302 (05-28-2018), idrive (04-23-2018)
post #2 of 8 (permalink) Old 04-23-2018, 07:32 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2677 Post(s)
Nice writeup and mod. Too bad our silly state thinks it's so important to have front plates because short of the toe hook (which I agree with you doesn't look OEM at all), there's nothing you can do to properly show off that beautiful grille and still be within the confines of the law.
Chazzy J likes this.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #3 of 8 (permalink) Old 04-23-2018, 07:35 AM Thread Starter
Chazzy J's Avatar
Quoted: 40 Post(s)
I'm sooooo on the same page with you. It's all so silly. That's ok though, with the right mods, we can get as close as possible haha
Chazzy J is offline
post #4 of 8 (permalink) Old 04-23-2018, 08:00 AM
idrive's Avatar
Quoted: 122 Post(s)
Nice write up! I am so grateful I won't be putting the front plate on....
2018 Signature
White Pearl - Chestnut
idrive is online now
post #5 of 8 (permalink) Old 04-23-2018, 08:05 AM
Shiro Shinobi
Byakuya's Avatar
This is actually the main reason I went with a toe-hook plate bracket - I can have it on while driving around so the cops don't get angry with me, but quickly pull it off and pop the cap back in for photoshoots and the like
Edit: Also, added this to my 3rd Gen 1 Stop Shop
kufliclicks likes this.
Current:
, Sold:
, 3rd Generation
Byakuya is offline
The Following 2 Users Say Thank You to Byakuya For This Useful Post:
Chazzy J (04-24-2018), idrive (04-23-2018)
post #6 of 8 (permalink) Old 04-23-2018, 08:50 AM
Mz6GreyGhost's Avatar
Quoted: 689 Post(s)
Groaned at 14 Times in 10 Posts
Love it! This may be the first mod I do if/when I get my '18...
Mz6GreyGhost is offline
post #7 of 8 (permalink) Old 07-08-2018, 06:44 PM
daddyd302's Avatar
Quoted: 11 Post(s)
https://www.cruiserframes.com/licens...ate-clear.asp#
I was gonna try this method but I found this item at autozone. It works ok but I'm a bit worry the bottom part will scratch the top part of the lip.
ID:	222887   Click image for larger version
daddyd302 is offline
post #8 of 8 (permalink) Old 07-10-2018, 08:47 AM Thread Starter
Chazzy J's Avatar
Quoted: 40 Post(s)
Looks good man. But I share the same sentiment with having it sit on the lower lip. I tried to get it as low as possible to expose the full grille, but I moved it up a smidge for that very reason. Glad you found a quick solution though. Looks good!
2018 Mazda6 Signature
- Soul Red/Parchment
Chazzy J is offline
The Following User Says Thank You to Chazzy J For This Useful Post:
