Overhead Console Replacement - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 03-04-2017, 07:42 PM Thread Starter
I replaced the front overhead console in my daughter's M6 today. I broke it back in Dec while trying to remove it to find power for the auto dimming mirror I was installing. I will say, this is one of the most fragile pieces of plastic I've seen in any car. Even gentle prying will break it. Good luck finding a used one. I had to fork out $90 for a new one.
To get it out, remove the two torx head screws behind the sunglasses holder. Then, there are two tabs on either side, about one inch in from the back. Press those in, and it drops right out. The electrical connectors are a pain - why do they always place the little tab you're supposed to press on the side of the connector you can't see? Big fingers don't help.
In the garage (and the driveway):
2000 Mercury Sable LS Premium Wagon 3.0 DOHC (Mine)
2003 Mazda Protege5 (Daughter #1)
2004 Ford Freestar SEL (heading out to pasture)
2008 Nissan Titan SE (Mine as well)
2010 Mazda 6i Grand Touring (Daughter #2)
2012 Toyota Camry LE (Wife)
Exocet is offline
post #2 of 2 (permalink) Old 03-08-2017, 12:58 AM
michaelsteinbach's Avatar
Quoted: 40 Post(s)
The sunglasses door broke on mine several years ago. Bought a new one on ebay. When I tried to push the hinge pins back into the console, the entire thing snapped in half. Back to ebay for a new console (I think it was used) and when I installed it, barely torquing the screws at all resulted in the plastic around the screw holes basically shattering. I used some large washers to get the screws to hold.
michaelsteinbach is offline
