HOW-TO: Install paddle shifters - 2016 Touring - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
  • 3 Post By mazpro2
  • 1 Post By Byakuya
  • 1 Post By derek0609
post #1 of 9 (permalink) Old 02-06-2017, 11:18 PM Thread Starter
mazpro2's Avatar
Quoted: 4 Post(s)
Post HOW-TO: Install paddle shifters - 2016 Touring
Hello all,
I know there is scattered information everywhere about installing paddle shifters on Sport and Touring Mazda 6s. After reading as much information as I was able to find online, and going to a dealership to get part numbers from a 2016 Grand Touring (got a vin number from autotrader lol), I bit the bullet and ordered the parts.
Disclaimer: I am not responsible if anything breaks on your car. This is a pretty simple upgrade, so don't worry, nothing should break (Except those little black tabs ) if you follow the steps.
PARTS:
Wiring: (BNK8-66-4M2) https://www.mazdaswag.com/oem-parts/...E5MzM1NSZyPTEw
Rear cover: (GJS2-32-049) https://www.mazdaswag.com/oem-parts/...NDA1NSZyPTM%3D
Paddle Shifters: (BHT1-66-3P0) https://www.mazdaswag.com/oem-parts/...MzM1NSZyPTY%3D
Bolts: Two options, local harware store, or Mazda ones. You need 4 bolts total.
-A: (GJS2-32-750) https://www.mazdaswag.com/oem-parts/...NDA1NSZyPTg%3D
-B: #10-32 x 1/2 in. Round-Head Combo from your local hardware store. Mine: (http://www.homedepot.com/p/Everbilt-...4391/204274805)
I decided to order everything at the same place to keep things simple. You may or may not find those part cheaper in other websites. My total cost was $180.44 before shipping.
The bolts I ended up buying at the local hardware store. Paid $1.18 for the pack of 4
NOTE I can only confirm this parts work perfectly for the 2016 Mazda 6 Touring, and most likely work on the 2016 Sport. Do your research if you do not have a 2016!
TOOLS:
21mm socket - To remove the steering wheel nut
10mm socket - To remove battery negative terminal
Flathead screwdriver
Phillips head screwdriver
Cutting Pliers
Blue Threadlocker
1. Loosen the airbag. At this point my car is on, so I can easily turn the steering wheel.
--- A: Use the Phillips screwdriver to push the tabs in the back of the steering wheel. There are 3, two on the sides, and one in the bottom. Picture below is for one of the side ones.
--- B: There is no need to use excessive force, as just pushing the screwdriver in will push the tab, and you will see the airbag come out a little.
--- C: Once the airbag is loose, DO NOT REMOVE IT YET, make sure the wheels are pointing straight, and turn off the car.
2. Remove negative battery terminal. SUPER IMPORTANT as we are messing with the airbag. You do not want it to go off while you are working on this.
DO NOT plug the battery back in without the airbag in place, this will most likely cause a check engine light that cannot be easily erased. Read about this on my online research
3. Once battery is unplugged, time to remove the airbag.
--- A: There are 3 plugs to remove, the highlighted green one is a ground, which pulls straight out.
--- B: The 2 red highlighted ones are the important ones. You can see a back tab on top of each one, you will need to use a small flathead screwdriver to pull it up slightly, as pictured.
--- C: Once the black tabs are extended, both entire plugs will pull off with you hands. They will take a little bit of force, but they come off. I DO NOT suggest you use anything other than your hands
--- D: Pull the airbag off, and set it aside, don't throw it around or put it on the floor to step on it lol. Back seat for me.
4. Take out the steering wheel
--- A: Unplug the white connector, highlighted in red
--- B: Take the 21mm socket and remove the main bolt. You will need to hold the steering wheel so it doesn't turn when you start putting pressure on the bolt.
--- C: Pull off the steering wheel. Note the airbag plug stays on the car
5. Remove the back cover of the steering wheel by pinching the 4 plastic tabs in red below. I did it as you see in the picture, putting pressure in the back with one hand, and used a screwdriver in the other hand to push down each side of each tab. (Thinking about it now, you can probably just use some pliers)
6. Remove the Steeering wheel controls to change the wiring
--- A: Pull off the plastic connector highlighted in pink
--- B: Lightly pull the tall plastic tab highlighted in green, and push the control out a little so it is not locked. (This is the tab the a lot of people break. Don't worry if it does)
--- C: Use a flathead screwdriver to put pressure on the two red plastic tabs and pull them out. This ones are really tight in there, so you will use a little bit of force. Put the tip of the screwdriver right on the base of the tab, so you don't break anything else.
--- D: Once those 3 are out, the control comes off.
--- E: Do the same to remove the other side
7. Switch the wiring
--- A: Cut the two zip ties highlighted in green with the cutting pliers
--- B: Unplug the blue connector and plug in the new one. Then unplug the gray connector and plug in the new one. (One at a time to make sure we don't plug the wrong cables)
--- C: The new wires come with 2 new zip ties to replace the ones you just cut out. Put them in.
8. Put the controls back on the steering wheel, and plug back in the white plastic tabs highlighted in red in place. Note I had not put mine back on the picture below.
9. Put the back cover on
--- A: First put the paddles on the back cover, and route the cable along the path, highlighted in red.
--- B: Put the complete back cover on the steering wheel with pressure, the 4 plastic tabs will click
--- C: Use the 4 screws you purchased, put a little bit of threadlock in each one and tighten the paddles with 2 bots on each side
10. Put steering wheel back on the car
--- A: Connect the white connector highlighted in red, this is the new one for the paddle shifters
--- B: Put the steering wheel back on the car, use some threadlock on the bolt and tighten.
--- C: Connect the white connector highlighted in green back on the car, and make sure the ground and two wires for the airbag are outside, like the picture
--- D: Make sure the steering wheel bolt is reeeeaaallly tight. I did not find the torque number needed, so I just made sure that bolt is tight in there, use those muscles.
11. Put the airbag back on the steering wheel
--- A: Connect the ground cable
--- B: Connect the two airbag connectors back on, and press the black tabs back down. The connectors are color coordinated, so plug the right ones in.
--- C: Push the airbag back in place with pressure. No battery means the horn is not going to go off lol
12. Plug the battery back in and go enjoy those paddles!
toy4x, derek0609 and jenjen777 like this.
mazpro2 is offline
The Following User Says Thank You to mazpro2 For This Useful Post:
Anderfrank (03-20-2017)
post #2 of 9 (permalink) Old 02-07-2017, 08:16 AM
Banned
Quoted: 20 Post(s)
Groaned at 6 Times in 4 Posts
my head exploded, i can barely assemble legos
Mazda6Power is offline
post #3 of 9 (permalink) Old 02-07-2017, 08:27 AM
Sound's Avatar
It's okay, its the same thing, these are just like really expensive legos
'16 Mazda 6 - iSport
Sound is offline
post #4 of 9 (permalink) Old 02-07-2017, 08:36 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2377 Post(s)
Groaned at 13 Times in 13 Posts
Good writeup sir! Added to my 3rd gen 1 stop shop
mazpro2 likes this.
Current:
, Sold:
, 3rd Generation
Who would have thought a businessman would be good at running a giant business?...
Need a Part Number? Find it
Byakuya is online now
post #5 of 9 (permalink) Old 02-08-2017, 06:41 AM
derek0609's Avatar
Quoted: 34 Post(s)
Thanks for the awesome write-up, this will be my spring project!
mazpro2 likes this.
2016 Mazda 6 I Touring
MR/Bose/Sat Package - Tech Package
AEM Dry Filter - CS Axle Back Exhaust - Autoexe Strut Tower Bar - Autoexe Hood Dampers - Autoexe Oil Cap - Autoexe Intake Suction Kit - Tanabe NF210 Springs - KONI Sport Yellow shocks - 19' Matte Bronze TSW Nurburgring Wheels
derek0609 is offline
post #6 of 9 (permalink) Old 03-20-2017, 11:05 PM
Anderfrank's Avatar
During all of your research, did you happen to come upon the part # for the trim pieces that cover around the buttons on the wheel? I had a 2014 Mazda3 GT and liked the look of the faux carbon fiber trim on the steering wheel and the 6 has that ugly plain black plastic. Great write-up by the way, I can't wait to do this to my car and your post will definitely help.
Also, I saw in other how-to's on the internet for this that people were buying a new steering wheel bolt because they said you should not re-use the existing one. Have you seen this? Do you have any concerns about re-using the existing bolt?
Anderfrank is offline
post #7 of 9 (permalink) Old 03-21-2017, 06:09 AM
Jerrycobra's Avatar
Quoted: 294 Post(s)
Very nice write up, can't believe I just saw this! I also have done this mod and can confirm instructions are exactly the same for earlier gen3s, I have a 2014. One thing to watch for is changing part numbers, I noticed that the wiring harness and paddles seem to change part numbers every year/2 or so.
also for future reference all the important torque numbers can be found here, courtesy of @Byakuya
2014 Full Interactive Workshop Manual
torque is 31-39ft-lbs. this is for a new bolt with thread locker. I used a new steering wheel bolt to be on the safe side.
from doing this mod it looks like you need to replace the whole button unit, the cover looks to be integrated/ replaced as whole assembly.
2014 Mazda 6 Touring Liquid Silver
[ OVT 91 octane tune ][ CS Power Series SRI ][ Racing Beat Axleback ][ Morimoto XB35 35w 5000k HID lows ][ LED interior lights and plate lights ][ 3M FX HP Tint ][ Dipped rims and dipped trim ]
Jerrycobra is offline
post #8 of 9 (permalink) Old 03-21-2017, 08:35 AM
Anderfrank's Avatar
That's kinda what I was thinking based on a quick parts search but thought it was worth asking. Not sure it is worth the money for the whole part just to get the trim piece. Maybe a decal of some sort would work the same.
post #9 of 9 (permalink) Old 03-21-2017, 09:00 AM
SVShootingStar's Avatar
Quoted: 61 Post(s)
Groans: 7
I added paddles to my 2014 Touring about 2 years ago. While I don't use them a lot, I do like having them for the occasional run through the twisties or a quick downshift. The nice thing is that you don't need to be in manual mode to manually select gears.
Whether it's installing the nav system, the Homelink mirror, or the paddle shifters, Mazda is great about making it easy to add accessories only found on the higher trim levels and packages.
SVShootingStar is online now
