Hey guys,
We have a crazy special on the Gram Lite 57 Optimise GRAM LITE 57 OPTIMIZE - 18x7.5 Dark Silver - +43 offset, 5x114.3 - Set of four $1299 Shipped!! ![]() Thanks ![]() Gary gary@gruppe-s.com 949-457-1234 ext 2228 |
Bump for a good seller!
But don't forget about the hub bore...... we are 67.1mm!!
L76-powered |
Weight? Do they come with hub centric rings?
'06 Black Mica Speed6 GT</span> ATP turbo-less 13.0 @ 105 MPH If you live in or around the Carolinas then check out <span style="color:#FF0000">Carolina Mazdas. Meets are scheduled monthly. |
Hi, the hub bores on most of the Volk / Advan line is about 73mm. We currently aren't including hub rings, but they can be purchased for $25 from discount tire. Thanks,
#5 (permalink) | |
The weight is listed as 19 lbs. on the Tire Rack website. They also show the Speed6 fitment at 48mm offset. Stock is 45mm ? Would there be brake caliper or suspension clearance problems with 43mm ?
Also, I looked at DiscountTire.com and couldn't find how to purchase the center rings. In fact they don't list Gram Lights on their wheel page. Do you have to go to one of their stores to get these ? I assume these let us use the stock Mazda center caps. If not what purpose do they serve ? Lug nuts included or can you use the Mazda nuts & wheel lock ?
'06 Speed6 Sport Ti |
#7 (permalink) |
For the speed6 id say the lowest you can go safely with little worries is 42.
2006 Velocity Red Mazdaspeed 6 GT Autoexe CF Front lip | Autoexe CF Grille | Autoexe CF Side Pillars | 18x8 TSW Trakstar 5 | Corksport FMIC custom pc'd | Turbosmart BOV | Corksport Res TP | AE Tower bar | Car-led tail lights | TWM shifter kit w/bushings | TWM Desert Eagle knob | Apexi Full-auto TT | Shark fin | 35% tint | Rear tinted reflectors | Nightshade clear side markers | Xtec Angel Eyes | Apexcone 6000k H1 | PIAA fogs | MSD DH | Prosport Boost/Vaccum Gauge | Audiolink Ipod Connector | COBB SRI | COBB shifter weight | SU rear engine mount | Goodyear Eagle GT | Muteki Lugs |
#8 (permalink) | |
Stock offset for the Speed6 is +55mm. The will not use the stock center caps. Yes you need thinner tuner lug nuts. Hubcentric rings and center caps are two totally different things. Hubcentric rings are simply rubber rings that fit over our stock hub so the larger aftermarket wheels fit snugly. A little reasearch and you should be able to find them for less than $25. |
#9 (permalink) | |
Thanks for the info ! I did figure out the offset after reading the sticky on the Wheels & Tires page.
So there is a chance that these wheels @ +43mm will need a fender roll (even with stock tire size) ? Quote:
#10 (permalink) |
GARY
I am interested in the 8.5x18 et 43. Are these also the same price? EDIT I got a quot for them and the sale is over, but price seems decent. Can anyone do a photoshop of these on the red speeed6? I will try myself when I get home, but I do not know how to use photoshop.
RENT FENDER ROLLER</span> CPE Standback - CPE catted DP to dual muffler CS mounts - CPE FMIC w/ OEM air dam & HKS BOV - mrlilguy CDFP - D N <span style="color:#4b0082">P - CPE CAI - speedie6 TIP - SU MM - TWM SS - TT Front MM - TT & CPE Rear Diffmounts - BC Coilovers - Brembo Front/StopTech & EBC Redstuff rear - F2 Baffle <strike>BS</strike> - <strike>VTCS & EGR</strike> - - 8.5x18et45 GM 57F's w/ 245/40 M3s / 18x8.5et45 Advan RZ GM w/ 245/40 Re01Rs - Passport 8500 X50 + LI Quad Laser Jammer - X50 mute button, Sub volume, LI swith & Dashawk custom mounted in steering column - EURO Tails - Rola Roof Rack - Prosport Boost gauge-Vent mount - TSX projector Retrofit - 55w projectors in fog retrofit - Carputer - CRX antenna w/ sat antenna mounted in front - Audison Dynaudio & Alumapro - Amsoil/Schafer Supreme |
