2016 Mazda CX-9 Long-Term Test Wrap-up - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 1 (permalink) Old 12-15-2016, 12:55 PM Thread Starter
Wrapping up our CX-9 long-term test, we look back at the highlights and flaws in Mazdaís flagship crossover.
Over the past four months, weíve thoroughly tested nearly every aspect of the Mazda CX-9. While itís an afterthought in the market, we wanted to know if it would be worth putting in your familyís driveway, so we put it through its paces to make sure it was up to the task. Our long-term test is over now, but before we let it go, here is what we learned.
As promised by Mazda marketing, the CX-9 is a blast to drive. Sure itís big and heavy, but itís also long and wide and low relative to others in the segment, so it has a great stance that benefits its driving dynamics.
The 2.5L Turbo has plenty of grunt to get it going, 310 lb-ft of toque to be exact, and it never seems to want for power, even when we run it on regular grade fuel, which puts its horsepower at a modest 227. Horsepower rises to 250 if you spend the extra coin on premium fuel, but we stopped doing that about halfway through our test after alternating at each fill-up over the first few months. As to the transmission, in the entire four months weíve had it, there hasnít been a single complaint or hiccup, so about the only fault we could raise with the powertrain is a bit of coarse engine noise.
Read more about the 2016 Mazda CX-9 Long-Term Test Wrap-up at AutoGuide.com.
AutoGuide.com is offline
