Hello, Does anyone know how to change puddle light bulbs? I have changed all my lights over to LED and would like to change the puddle lights too. Thanks for your help.
#3 (permalink) | |
QUOTE (Nealio @ Oct 15 2008, 11:23 PM)
[b]"There are three easy ways of losing money - racing is the quickest, women the most pleasant, and the Stock Market the most certain."</span> |
The puddle lights are I'm guessing the lights on the the botom of the side mirrors, comes on the Grand Touring or the Touring with convinience package.
#6 (permalink) | |
QUOTE (Brainbasher @ Oct 16 2008, 06:32 AM)
That is correct, Now I just need to know how to change them.. |
#7 (permalink) |
The manual for mine says that "Due to the complexity and difficulty of the procedure, the bulbs should be replaced by an Authorized Mazda Dealer."
It says the exact same thing for the taillights if they are the LED version, so maybe the ground illum. lights are already LED? *pause while I go check* ... Ok, It's pretty easy to remove the lens. Use a small flat screwdriver to lightly pry the edge of the lens opposite to the black rectangle on the inner edge. Once the edge is loose, there is a small clip that will prevent that side from coming out any further. Slide the lens away from the door so that the clip above the black rectangle comes loose and then the module should pull straight down. As you might be able to see in the pictures, the module is enclosed. The lens is either glued or melted to the black plastic housing. The module has two terminals with wires soldered to them, heatshrink around each one. My guess is thast there are LEDs in the lamp module. ![]() ![]() (Sorry about quality, they were taken with my LG Dare in a dim garage.)
2009 Mazda 6 GT in Sangria Red. |
#8 (permalink) |
Thank you for all your help! They just don't look like LED's to me. A little to much yellow. I was hoping that I could change them to white. Thanks again, and thanks for posting the pics.
#10 (permalink) |
Why would you want to light up puddles anyway.? ![]()
