Sold Out, All Gone, None Left -Speed6 Turbo Oil Restrictor Bolts
Oil Restrictor Bolts for Speed6 K04 turbo
These are modeled after the original bnoon bolt to restrict oil flow into the turbo and help prevent the smoking turbo syndrome.
Been using the first bolt I drilled in my car for over 10,000 miles with great results & have several more scattered across the country with equally good results. When used with 5-40 oil and a raised idle my Speed will sit all afternoon without smoking. The bolts for sale are identical to the bolt I'm using in my own Speed6.
These are the last I'm going to make, after this no more.
M12x1.5 pitch bolt, 30mm length
side hole size .0635"
center hole size- 15/64"
There are 13 in the pic, one is on the way to Lithuania, and the remaining 12 are available for sale.
Edit: down to Sold Out, All Gone, None Left for sale now
$20 shipped in the continental US.
If you're not in the lower 48, shoot me a PM with the shipping address & I'll get you a quote
