#21 (permalink) | |
Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 141 Post(s)
iTrader: 14 reviews
EDIT: Have Ti make you one instead, he enjoys hard labor |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) |
Quoted: 37 Post(s)
That just sounds dirty...
2007 TGM Mazdaspeed6 GT COBB AP - DENSO ITV22 PLUGS - COBB SRI - COBB TIH - CUSTOM BORLA CAT-BACK - TWM STAGE 2 SHORT SHIFTER - JBR HEAVYWEIGHT KNOB - TWM SHIFTER BUSHINGS - LED INTERIOR LIGHTS - RPM IPOD CONNECTOR - BLOCK8HEAD GAUGEPOD - PROSPORT BOOST/VACUUM/OIL TEMP GAUGES - CHARGESPEED STI LIP - PLASTIDIP'D OEM WHEELS/CONTI EXTREMECONTACT DWS (WINTER) - PLASTIDIP'D MS3 WHEELS/BRIDGESTONE POTENZA S-04 PP(SUMMER) My Speed6 #09241 is registered- How 'bout yours? - ms6db.com |
#23 (permalink) | |
Quoted: 46 Post(s)
Liquid Platinum 07 Speed 6 #10177JBR 80duro RMM, Sure Juggernaut, Sure Dreadnaught Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Clean Valves! ![]() LED tail lights, 20% tint, EVO X rims and VG Sharkfin Soon to be installed: Ford Transit Oil Filter Conversion |
#24 (permalink) |
Groaned at 5 Times in 5 Posts
Quoted: 229 Post(s)
Get at least 2 of the small bit & 3 bolts. Most important is to have a drill press with a vice to hold the bolt.
The small bit will flex if you use too much pressure, so use a punch so the bit will have a good start. My first bolt was a fail on the side hole & bit. Second bolt is in my car. I bought 25 bolts, 3 little & 2 large bits from McMaster-Carr for the same $40 that boon charges for one...
Mazdaspeed6 GT #3476 TiGray slicktop bolted & tuned by my own hand 405/394 AWD - cf1.01 BNRs3 315/372 AWD - cf1.01 k04 |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | 6erforlife (12-06-2012) |
#25 (permalink) | |
Quoted: 46 Post(s)
My friend has the drill press, I just have to bring the supplies. I'll probably check the local hardware stores before I go name brand like Lowes, HD, etc. I haven't touched a drill press since shop class in elementary school so we'll see how this goes haha
#26 (permalink) |
Quoted: 132 Post(s)
Every time this pops up I think, "YES!" and then I click in.
Upon recalling that this is probably another question/bump I then get very sad. This won't be a happy Christmas after all. ![]()
If all else fails, you weren't driving a Mazda6 Handling: H&R lowering springs - Tokico Blues - OPC ball joints - Whiteline Rear Sway Bar - Adjustable Endlinks - DBA 4000 Series rotors w/ Hawk HPS Pads Front and rear Stereo: Metra single DIN plate - Kenwood Excelon x950 Headunit - Kenwood Excelon shallow mount subwoofers - Boston Acoustics SR60 separates up front - Rockford Fosgate T500-1bdCP, Rockford Fosgate T400-4 Prettified: Speed6 rims powdercoated black - Tinted windows |
#27 (permalink) |
Quoted: 229 Post(s)
How about $12 & free shipping?
Turbo Banjo Bolt Mazda Speed 3 6 w Restrictor to Prevent Exhaust Smoke | eBay
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | oh_yeams6 (12-07-2012) |
Advertisement | |
