DIY: Oil Change - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 113 (permalink) Old 06-25-2013, 01:21 AM Thread Starter
DIY: Oil Change
Didn't see one posted yet so here we go! I take zero responsibility if you screw it up, follow at own risk.
Tools required:
1. Jack + Jack stands (or a ramp would do fine)
2. Wheel blocks
3. Hockey puck (optional; to put between the jack and frame)
4. 8mm key
5. Screw driver
6. Flat head screw driver
7. Filter Wrench (Factory filter is a PITA to take off without one)
8. Pliers (to take off the factory gasket on the drain plug, mine was pretty stuck on there)
Oil + Filter
1. Mazda 0w-20 with Moly x 5qts
2. Mazda Oil Filter Part Number PE01-14-302
3. Drain plug gasket Part Number 9956-41-400
Step 1: Jack up your car and lay down your jack stands. ALWAYS USE JACK STANDS AND WHEEL BLOCKS
Here is the location that you want to jack. First image is taken from the front of the car. It's right smack middle of the picture with the, the location has dimples.
Here is another picture of the location, this is taken from driver side
Step 2: Remove oil drain/filter cover
The cover is held up with 2 screws and a pop off screw. The location is circled in this image.
Once you take off the cover, this is what you will see:
Everything is right there for you! Very easy. Drain plug is a 8mm allen and it uses a washer gasket.
Step 3: Drain oil and remove filter
You might need to use a plier to take off the washer from the drain plug
Step 4: Put everything on the bottom back together, less the cover (to check for leaks later)
Step 5: Fill oil from top
I took off the engine cover so it's easier to work with
Car takes about 4.7~4.8qts of 0w-20 (in the US)
Run the car for a couple of minutes and check for leaks all around.
If no leaks are found, put back the oil drain/filter cover.
Check oil level.
Remove the car from jack stands and take it out for a quick spin! Double check and triple check for leaks. You are done!
Happy zooming!
ps. forgot to take picture of jack stand location but you guys are smart... I use a towel between the jack stand and the lift location.
Edit: Mods, please move to DIY section. Thank you.
2014 Mazda 6 Touring
2004 Mazda 6s 5-door
Last edited by hiing; 06-25-2013 at 01:46 AM. Reason: Request for thread to be moved to DIY section
hiing is offline
The Following 10 Users Say Thank You to hiing For This Useful Post:
6-Speed (08-20-2015), jon2002 (02-26-2014), JSRhett (02-09-2014), KODO-6 (09-21-2013), kylekill (08-15-2016), martinezim1127 (04-14-2015), mcbru (09-18-2015), Sideways the Seven (01-06-2014), spikeit1 (04-12-2014), wmillerjp (06-20-2015)
post #2 of 113 (permalink) Old 06-25-2013, 07:28 AM
Thanks for the write up and pics!
Interesting to see 8mm allen as drain plug...and very cool that the filter and drain plug are actually near each other!
Nice work.
flash40 is offline
post #3 of 113 (permalink) Old 06-25-2013, 07:43 AM
Quoted: 68 Post(s)
Groans: 13
Groaned at 6 Times in 6 Posts
Is the filter housing plastic or metal? Also, does the new filter cartridge come with a new gasket for the housing?
xtmesisx is offline
post #4 of 113 (permalink) Old 06-25-2013, 08:09 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2377 Post(s)
Groaned at 13 Times in 13 Posts
I LOVE how easy it is to change the 2014's oil - about damn time car manufactures did this.
Moved to correct section
Current:
, Sold:
, 3rd Generation
Who would have thought a businessman would be good at running a giant business?...
Need a Part Number? Find it
Byakuya is online now
post #5 of 113 (permalink) Old 06-25-2013, 02:35 PM Thread Starter
The housing is metal, oil filter comes with an o ring.
hiing is offline
post #6 of 113 (permalink) Old 06-29-2013, 07:53 PM
Quoted: 13 Post(s)
I did my first oil change a couple of weeks ago. The manual says that with a filter (primed) it takes 4.8 quarts. I put a full 5 quarts in before the dipstick read full (and just barely). The garage is level and I ran the car for a bit with 4.5 quarts in it then let the oil settle for a good half hour before I checked the dipstick and topped it off. Checked the oil a couple days ago and it reads right on the full mark. Not even a hair over. Strange.
the_3d_man is offline
post #7 of 113 (permalink) Old 06-29-2013, 08:03 PM
Jjkalai's Avatar
Quoted: 123 Post(s)
Groans: 6
Groaned at 8 Times in 6 Posts
Wowww.
I'm glad Mazda finally decided to use normal oil filters for these cars.
Cobb AP - CP-E Nano SRI - CP-E Single exit CBE - CP-E RMM - PG TIP - SLS TP - Forge V1 BPV - HKS Hipermax LS+ Coilovers - Car_LED Tails - Prosport Gauges - Dashhawk - JBR SSP/Counterweight/Bushings/Heavy Shift Knob
- SOLD
Instagram: JKalai
Jjkalai is offline
post #8 of 113 (permalink) Old 07-01-2013, 09:22 AM
RacingTiger03's Avatar
Quoted: 494 Post(s)
Groaned at 5 Times in 5 Posts
allen key for drain plug.. what the.. O_O. That's a lot easier than I would've expected. I hated the old mazda cartridge filters. And that oil filter spot looks easy to grab and change You should see the one under my old car.. or for that matter under my second car I ever owned. Had to buy a special wrench from the tool truck that attached to a ratchet and still gave me a fit. Usually ended with a screwdriver through the filter.. ';..;' at about a 15 degree angle (off vertical!) no less.. and several sets of holes LMAO
2013 Volt (family car)
2013 MX5 Club PRHT (wife's toy)
2001 Firebird Formula (my toy
RacingTiger03 is offline
post #9 of 113 (permalink) Old 07-12-2013, 06:39 PM
biking4jesus's Avatar
Quoted: 106 Post(s)
thanks for the write up and pics!
05 Mazda3 Hatch
biking4jesus is offline
post #10 of 113 (permalink) Old 08-19-2013, 12:55 AM
Jerrycobra's Avatar
Quoted: 294 Post(s)
very nice, thanks for the write up. I think i will let the dealer do the 1st few changes, than after that i am going to tackle it myself, it looks straightforward enough
2014 Mazda 6 Touring Liquid Silver
[ OVT 91 octane tune ][ CS Power Series SRI ][ Racing Beat Axleback ][ Morimoto XB35 35w 5000k HID lows ][ LED interior lights and plate lights ][ 3M FX HP Tint ][ Dipped rims and dipped trim ]
Jerrycobra is offline
The Following User Says Thank You to Jerrycobra For This Useful Post:
diamondping (01-04-2015)
