#71 (permalink) |
Good to hear, really was trying to avoid bleeding the brakes if possible.
Tig, whats your thoughts on the Centric Cryogenic blank rotors Vs the Centric blank non-cryo treated rotors? I am leaning towards the less expensive non-cryo but don't want something inferior to at least OE.
'06 Titanium Gray Metallic MS6 GT XCarLink, Shark Fin, Conti DWS 225/45, |
| Sponsored Links | |||
Advertisement | |||
#72 (permalink) |
Groaned at 5 Times in 5 Posts
Quoted: 210 Post(s)
To me, it's totally "Meh....., whatever"
I don't autocross or track day my car, just aggressive street driving. I love my brakes, but I'll get two sets of pads on one set of slotted rotors before replacing, over 100K miles. Cryo makes em more durable, but I can spend that extra ~$50ish on something else...
Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04
#73 (permalink) | |
![]() On my previous car (350Z) I was getting roughly the same amount of mileage on my slotted rotors w/ Hawk HPS pads. Anyway, thanks!
#75 (permalink) |
Quoted: 210 Post(s)
If your just topping off, any good DOT4 works. Prestone is fine if you want a name to look for.
If you're flushing with fresh, I'm a huge fan of SuperBlue and it's Amber twin simply because the color change makes flushing soooo easy. And, for the record, if you've never flushed your fluid, you've timed out & it really needs to be done!
#76 (permalink) | |
Quoted: 194 Post(s)
| The Following 2 Users Say Thank You to Final Impact For This Useful Post: | JDspeed6 (01-04-2013), TiGraySpeed6 (01-03-2013) |
#77 (permalink) |
I am being lazy about it because of my work enviroment, very cold outside! But your both right, I need to do it and beings I'm replacing my brakes and rotors no better time to do it then now.
Excuse my ignorance but will I have to bleed all four brakes, there is not a seperate resevoir for front and back right? Reason I ask is I'm only trying to replace the front at this time and having all 4 tires off the car isn't likely, don't have 4 jack stands or a lift.
'06 Titanium Gray Metallic MS6 GT XCarLink, Shark Fin, Conti DWS 225/45, Last edited by JDspeed6; 01-04-2013 at 10:41 AM. |
#78 (permalink) |
Quoted: 210 Post(s)
While a simple bleed can be done on just the corners serviced if needed, bleeding, or flushing, is ideally recommended to touch 5 points- don't forget the clutch which shares the common master cylinder & fluid with the brakes.
Again, considering the age of your fluid I'd encourage flushing the entire system with fresh. Using something like a Motive Power Bleeder makes it an easy fast painless one person job.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | JDspeed6 (01-04-2013) |
#79 (permalink) |
Ahh, forgot about the clutch fluid too. I just decided I'm ordering everything and bringing it to my mechanic to do, don't feel like tackling this one right now. I can't wait to sell my home and get one with a huge garage!
BTW, will 4 bottles of brake fluid be enough for a complete swap? Thanks again TiGray, your the man!
#80 (permalink) |
Quoted: 210 Post(s)
It's never taken me more than a liter, but not everybody is so lucky
With 4 it's possible one bottle won't even be opened, but sure is a PITA to run out 99% of the way through, just ask @IHeartGroceries;
Advertisement | |
