DIY: EGR Modification/Optimization (3.0L V6) - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > How-To / DIY Section > Mazda 6 1st Generation (2002-2008) > Engine / Suspension / Drivetrain
New User? Register
Old 01-20-2008, 03:17 PM   #11 (permalink)
Yay! this how to was essential! thanks!
04 v6 MTX - 238.8 WHP (w obx headers) - 17" Enkei RS+M rims with Goodyear Eagle 215/45. Performance Mods: AEM CAI, Magnaflow Mufflers w/ customized exhaust, CP-E Headers, Apexi SAFC II, optimized throttle body, Racing Beat Rear Sway Bar, EGR Mod, component polk system with a 12" sub and alpine amps, 7k HID headlights, DDE's, and more. All self installed! check out my APEXI install/dyno/settings thread and my OBX header install/dyno/APEXI settings thread To come: optimizing exhaust WTB: steel grey eyelids
hot6onaplatter is offline   Reply With Quote
Old 01-20-2008, 03:33 PM   #12 (permalink)
The Great NY's Avatar
Groans: 7
Groaned at 39 Times in 33 Posts
hey no problem guys. as much info as i get from all of u i figured i'd try to give back somehow. glad everyone found this useful.
Punisher 6 - Twin Turbo - Noble Hybrid V6
"H.A.T.E.R.S- Having Anger Towards Everyone Reaching Success"
"FULLY BUILT AND SPOOLIN" -CLICK ME
FOR MAZDA 6i/6s TUNING & MAZDA6/SPEED6 TCS Auto-Off Module - PM Me for Info
The Great NY is offline   Reply With Quote
Old 01-20-2008, 03:39 PM   #13 (permalink)
Groans: 7
good write up there. I just might do this today and the TB coolant bypass if I can figure that one out too. anyone have a link to the TB coolant bypass or if there is a how-to on that?[/b]
all u need for this is i believe a hose splicer to connect the 2 hoses to each other. maybe 2 proper size hose clamps. it'll leak some coolant but nuthing major. u could use a red plastic cup to catch the fluid
Old 01-21-2008, 09:50 AM   #14 (permalink)
VirtualMirage's Avatar
Does anyone know what the torque specs are for the bolts holding down the intake manifold, the EGR valve, and the throttle body (if I end up removing the throttle body)? I just want to make sure it is torqued properly without over/under tightening.
I used to remember the torque specs for the throttle body but forgot.
Paul
2007 Mazda6s GT 5-Door, Tungsten Grey (Auto, 6-speed) : >>> My Garage <<<
1/4 Mile: 15.609s @ 89.69 MPH <-- MIR, 3/1/08. Burnout done for traction, Brake torqued around 1700RPMs, Wheelspin off the line. Low trap time due to Cyl #6 misfire.
0-60 MPH (60.3 actually): 6.45s <-- Timed with MSD DashHawk (TCS off, D Mode, no brake torque, some wheelspin off the line). Repeatable. Time should improve with better launching and better tires.
Dyno/Tune (Conservative timing adjustment) 1/26/08 ---> 182.53 HP / 172.33 TQ at the wheels (SAE format)
VirtualMirage is offline   Reply With Quote
Old 01-21-2008, 10:10 AM   #15 (permalink)
I believe I found the torque specs for the intake manifold, thanks to a message Fly757 left in a previous post. Here is a direct quote pulled from that topic:
-A torque wrench is always recomended for things like the intake manifold. You could get away with doing it by hand, but then you're taking some risks.
The upper intake manifold bolt pattern is as follows:
7 1 3 5
8 4 2 6
Torque 72-106 in-lbs. Work slowly and progressively, and in the correct order.[/b]
Now I just need to dig up the specs for the EGR valve and the TB. I'll post them if I can find them.
Paul
Old 01-21-2008, 02:02 PM   #16 (permalink)
I'm in the process of doing mine now. That third hose under the TB is a pain in the ass to remove, I was unsuccessful removing it since it was stuck on the IM so well. Also, don't forget to take a vacuum hose to the EGR valve when finished to suck up any metal shavings/dust that may accrue in what's left of the tube prior to reassembling. I used a dremel cutting wheel on mine and it left some shavings and dust in the egr valve, nothing a vacuum couldn't handle.
Old 01-21-2008, 02:29 PM   #17 (permalink)
Groans: 7
I'm in the process of doing mine now. That third hose under the TB is a pain in the ass to remove, I was unsuccessful removing it since it was stuck on the IM so well. Also, don't forget to take a vacuum hose to the EGR valve when finished to suck up any metal shavings/dust that may accrue in what's left of the tube prior to reassembling. I used a dremel cutting wheel on mine and it left some shavings and dust in the egr valve, nothing a vacuum couldn't handle. [/b]
hey bro. i just added all the TQ specs for everything on top of the motor.
its in my first post just right after step #11. just click to enlarge. hope that helps!
Old 01-21-2008, 03:38 PM   #18 (permalink)
Raynman's Avatar
Send a message via ICQ to Raynman Send a message via AIM to Raynman Send a message via Yahoo to Raynman
Seriously, this How-To is reminiscent of quality Mazda6tech articles.
04 Mazda 6s 5 Door
Raynman is offline   Reply With Quote
Old 01-21-2008, 04:11 PM   #19 (permalink)
84FordMan's Avatar
I made it sticky...
1994 Mazda B3000 SE
Daily driver
84FordMan is offline   Reply With Quote
Old 01-21-2008, 04:46 PM   #20 (permalink)
Groans: 7
Seriously, this How-To is reminiscent of quality Mazda6tech articles.[/b]
thank you kind sir
I made it sticky...[/b]
appreciate it bro. this should stop the random WTF is the egr mod questions that pop up from time to time.
yeeyah baby, my 1st sticky, lol!
