04 mazda6 2.0 wont run power to coil and injectors fades out - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 1 (permalink) Old 09-30-2013, 02:16 PM Thread Starter
Unhappy 04 mazda6 2.0 wont run power to coil and injectors fades out
Hi new to the forum I have an 04 mazda 6 2.0 four cylinder, The car wont run it seems to catch at first for about 1 or 2 seconds then just cranks over I put a noid light on the injector plug end and it flashes bright at first then fades out the longer you crank the engine i keep the battery strong, soo i was thinking ground issues soo all the gounds i could find on the motor fender radiator support and fuse block i cleaned and checked and checked the battery ground cable and even ran a couple new ground feeds did find some dirty grounds havent checked or cleaned any on the pass side of the engine bay , mazda had it at one point compression checked out timing as well and fuel system as well they said that mew coil pack wires and spark plugs would remedy the issue did that right out side the dealer shop after 90 bill nothing they said it was due to weak spark I dont know what else to do, any help would be greatly appreciated i work on alot of cars appearently Ive met my match with this one lol
Thanks
dals6man is offline
