error p2177 with K&M filter - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain
New User? Register
Old 02-26-2013, 07:14 PM   #1 (permalink)
Default error p2177 with K&M filter
Hey all,
I installed a k&M filer and now I'm getting the P2177 error. I tried to clean my MAS and the CEL went out for about a day and not its back on. Am I doomed to use a stock air filter or is there something else I can do? I have an 05 6s wagon 3.0L
05 Mazda 6s wagon green - looking to improve performance
Grand Poo Bah is offline   Reply With Quote
Old 02-26-2013, 08:19 PM   #2 (permalink)
Tj_Blaire's Avatar
Groaned at 7 Times in 7 Posts
Quoted: 185 Post(s)
Is that fuel system to lean? Our cars tend to do that with aftermarket filters. If its actually throwing a CEL and you have an aftermarket intake you should look into getting an air straightener.
Tj_Blaire is online now   Reply With Quote
Old 02-26-2013, 09:08 PM   #3 (permalink)
Can you let me know what an air straightener is. I have a stock air intake system.
Old 02-26-2013, 09:28 PM   #4 (permalink)
ctmazda's Avatar
Quoted: 182 Post(s)
It's for intakes with a bigger than stock size to reduce the airflow and essentially bring the inside diameter back down to stock. Not useful on a stock intake.
Sent from AutoGuide.com App
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is online now   Reply With Quote
Old 02-26-2013, 09:39 PM   #5 (permalink)
So I'm guessing that I should go back to the stock air filter unless I want to do more mods? Also, just a note, when I put in the K&M it didnt fit really tight into the air box.
Old 02-26-2013, 09:46 PM   #6 (permalink)
elemento_74's Avatar
Quoted: 34 Post(s)
Default Re: error p2177 with K&M filter
Did you mean K&N?
From what you said on the last post,I assume its not a CAI.If that's the case,no need for an air straightener.I think the problem is that the filter isn't fitting properly in the air box,and is letting too much air in.I just find a bit weird that a K&N would do this
Sent from my SAMSUNG-SGH-I727 using AutoGuide App
K&N CAI,Magnaflow exhaust,HID driving & fog lights,DoubleDin stereo with NAV,VIS carbon fiber hood,Autoexe grill & lip,Motegui 18' rims with Hankook tires,speed6 brakes,Steel braided lines,TB coolant bipass,TB grounded,PKE alarm system,Mazdaspeed short shifter
elemento_74 is online now   Reply With Quote
Old 02-26-2013, 10:58 PM   #7 (permalink)
ctmazda's Avatar
Quoted: 182 Post(s)
Maybe it's upside down or you got one made for a different year or engine size etc.
Old 02-26-2013, 11:04 PM   #8 (permalink)
yes it's a K&N, I hate small keyboards. So now for the stupid question: The pleats go down? and the flat side faces up? If I have it in upside down, I'm going to feel REALLY stupid.
Old 02-27-2013, 12:15 AM   #9 (permalink)
Originally Posted by Legacy View Post
Just sell the car. These Mazda 6 cars are some of the worst built cars out there.
I love my Mazda 6. I drove it off the lot with 6 miles on it and it has 168k. I have had very little issues with it. This is the FIRST time I have received an CEL code that wasn't the gas cap. And it's probably because I changed something.
If you are so unhappy with yours; why are you on this forum?
Old 02-27-2013, 12:19 AM   #10 (permalink)
Knupsel's Avatar
Groaned at 4 Times in 4 Posts
Quoted: 493 Post(s)
Don't listen to that clown, he's just pissed that his mazda died out on him (something oil related)
Anyways if you have the right sized filter it should fit snugly into the box!
I'm not sure what way is up and which is down though, since I have a CAI
So if your filter is moving around in the box that's probably your problem!
Sent from the Desert using Psychic Abilities
Knupsel is online now   Reply With Quote
