#21 (permalink) | |
04 mazda6--- Eibach springs*front & rear RB sway bars*CP-E yellow engine mount*Injen exhaust/kartboy hangers* black tail lights*19'' hyper black motegi racing rims/summer tires*8000k hid xenon*triple Lotek gauge pod*defi oil temp gauge/defi oil pressure guage/defi tranny temp gauge*HPS brake pads & RBF brake fliud* 91 Mr2--- turbo swap*ct20b turbo*3'' exhaust*3'' Downpipe*k&n intake* |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) | |
Quoted: 11 Post(s)
nautilus headers/mf cat back/tb bypass/tb spacer/ k&n CAI/ AWR lower engine mount 70duro/b&m tranny cooler/magnetic tranny filter/4v cobra coils/v-power ngk plugs/55w HID/7k angel eyes/ all interior blue LED bulbs/EGR reroute mod/sylfex aux mod/IM spacer |
#23 (permalink) |
Sorry I thought it meant something else but yes i do have a new gasket o ring for the thermostat that im using.
#24 (permalink) |
Hello again.
It has been a month since the car was repaired so I am now confident enough that the problem has been solved. Surprise surprise...it was the head gasket. My experience with second hand cars is that when something goes wrong it is the head gasket, even if it isn't - it is! The previous owner hadn't taken care of the radiator, which was in an awful state, and the knock on effect was a broken seal in the gasket. Radiator replaced, gasket replaced, 140kmh for an hour without issue. Thanks Last edited by AlanD; 09-30-2012 at 04:01 AM. Reason: spelling |
#25 (permalink) | |
#26 (permalink) | |
I am in the UAE, I am quite sure my pricing is going to be different to yours (probably a fair bit cheaper). Parts and labour, radiator included, about $300 |
#27 (permalink) |
banana boat.
Quoted: 116 Post(s)
300 bucks for a HG? must be a 4 cylinder.
#28 (permalink) |
Quoted: 194 Post(s)
As a last resort and when no other progress can be made you may try pulling the right side of the car onto a curb and make it higher. Some times a small elevation change can get things moving like trapped bubbles.
Also you can rent or buy pressure testers and pressurize the cooling system. It should not leak down. This can find bad head gaskets but not sometimes they have to be further along into failure mode. . . OP - it reads as if you did not solely rely on the instrument panel gauge. What else did you use?
#29 (permalink) | |
Final Impact, I'm also running a oil temp gauge so when the car starts heating up the oil temp starts going way up. Sometimes the water temp gauge would be normal and my engine oil temp would go up towards 240*F(normal temp is 215 *F) and then the water temp gauge would start moving from the middle.
#30 (permalink) |
I replaced the radiator(easy job) and I been trying to burp the cooling system for couple hours now. There is no leak coming from the radiator now and I've got my heat back after burping for so long. It still overheats but takes awhile to get to high now. So these signs are looking good now.
I went to check for leaks after i came back from a drive and there is a big leak coming from the rear of the engine. Right from where the sway bar is in the middle. I haven't gotten underneath the car yet to look from where its coming from as I ran out of time for the day. Any guess from where it could be leaking from? TB? heater core?
Advertisement | |
