Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain
Old 11-13-2009, 10:09 AM   #1 (permalink)
cybersonic's Avatar
Hi guys, I have a 2007 Mazda6 i with close to 50K miles. I had problem starting the car. I seems like it needs battery power to start. After several try with the key it turns on. I took it to Kragen and had it tested out. Starter and Alternator is good, but battery is low so i bought a new battery. I installed the new battery and now the car turns on nicely.
Problem: after several days, I would be driving the car the the wheel will lock up and everything would turn off completely. I took it back the Kragen for another test and everything turns out good. The car would turn off several times while driving it, all i have to do is turn it back on. Is it electrical, engine, or something?
Thanks alot guys.
2007 Mazda6i 2.3L Automatic Sedan = Tein Htech Springs, BOMZ Short Ram, BS Delete, Aux. Thermal Fan Cont., 2.25" custom piping cat back, 3" Tips, Stock mufflers, Brake Light Mod, Low Beam HID 6000K, Ground Wire Kit, Clear Side marker, Windows Tint, Rear De-badging, Fog Light Solution, Headlight Eyelids, Sport Mesh grill, Audio Link USB Mp3 Player
cybersonic is offline   Reply With Quote
Old 11-14-2009, 10:36 PM   #2 (permalink)
karlt10's Avatar
QUOTE (cybersonic @ Nov 13 2009, 09:09 AM)
Thanks alot guys.[/b]
If the wheel truly locks -and it's not just your P/S losing power- I'd have to wonder about something mechanically wrong with the ignition. But how and why in so new of a car seems odd.... Doesn't happen to be a theft recovery that had the ignition punched out, does it?
'05 S wagon: MazdaSpeed springs & sway bars / Tokico HP shocks / Racing Beat end links / GTSpec Trailing Braces / MazdaSpeed CAI / EGR mod / FilterMag / Racing Beat exhaust / Street Unit engine mount / StopTech brake lines / Hawk HPS pads / B&M trans cooler - Inline trans filter - Redline D4 fluid / Mazda iPod adapter-CX7 antenna / Hella FF50 lights--Coming- Steeda shock tower brace--To install- MSDS headers & Magnaflow cat; lightweight pulleys--??- Fluidamper; oil cooler
karlt10 is offline   Reply With Quote
