poor gas mileage. Don't know why - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 17 (permalink) Old 10-23-2009, 12:05 PM Thread Starter
I have a 2004 mazda 6i with 110k. It normaly gets about 650 to 700kms per tank but lately it's been getting 550 to 575 kms per tank. I've cleaned the CAI filter, cleaned the MAF, and replace the spark plugs. I thought the low gas mileage might have been caused the advanced timing mod and the coolant bypass mod so I reverted the mods and the gas mileage is still horrible. I get not engine lights. I just replaced the passanger side wheel bearing and i think the passanger side CV might be going. Could a bad CV cause poor gas mileage? What else could cause the problem?
Cheers.
mahzda6 is offline
post #2 of 17 (permalink) Old 10-23-2009, 12:11 PM
bmorrisj's Avatar
tire wear/alignment?
seasonal change in fuel formulation at the pump?
2007 w/ Cheez
// COBB AP // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs //
Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber
// Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob //
bmorrisj is offline
post #3 of 17 (permalink) Old 10-23-2009, 02:30 PM
low tire pressure?
low compression on cylinders?
used different gas, higher octane rating?
bad wheel bearing?
brakes rubbing?
EGR stuck in closed position?
dirty TB?
lead foot?
what else?
2004 MAZDA 6S 5 DOOR HATCHBACK,STEEL GRAY, ATX
KNN CAI, MAGNAFLOW EXHAUST
TRUECOOL LPD TRANNY COOLER
EVOKE 17X7 GUN METAL RIMS, 225/45/17 ZR NEXEN N3000 TIRES
seigfredm is offline
post #4 of 17 (permalink) Old 10-23-2009, 04:05 PM Thread Starter
QUOTE (seigfredm @ Oct 23 2009, 11:30 AM)
low tire pressure?
bad wheel bearing?
brakes rubbing?
dirty TB?
lead foot?
what else?[/b]
tire pressure is fine, just replaced wheel bearing, brakes are fine, installed OTB two months ago, always use 87 octane gas, and I dont have a lead foot.
is it easy to clean the EGR? Where is it located?
mahzda6 is offline
post #5 of 17 (permalink) Old 10-23-2009, 07:17 PM
http://forum.mazda6club.com/index.php?show...p;#entry1237904
I'm not sure if it's the same set-up though
post #6 of 17 (permalink) Old 10-25-2009, 04:33 PM Thread Starter
QUOTE (seigfredm @ Oct 23 2009, 04:17 PM)
I'm not sure if it's the same set-up though[/b]
is this correct picture of the EGR valve for the mazda 6i 2004?
mahzda6 is offline
post #7 of 17 (permalink) Old 01-07-2010, 05:08 PM
QUOTE (dido123 @ Oct 23 2009, 08:05 AM)
Cheers.[/b]
Have you had the car's ECU scanned for codes? I had mine scanned and found two O2 sensors stuck lean, which I believe would account for the poor mileage I've been having. Only thing is at over $120 each (and that's from Pepboys not the dealer) I don't drive enough to justify the cost versus money saved at the pump.
TDiddy is offline
post #8 of 17 (permalink) Old 01-17-2010, 12:31 AM Thread Starter
i had an oil change done a couple weeks ago and at the same time they updated the ecu. After the update the car was more responsive but still has poor gas mileage. The dealership said there were no codes. I was going to attemp to change the pvc valve today but its nearly impossible to remove the bolts. I will try it again another day. I am now getting around 530kms a tank. The car is feels sluggish and the other day the jerked a couple times during a hard acceration from start.
mahzda6 is offline
post #9 of 17 (permalink) Old 01-17-2010, 01:43 PM
QUOTE (dido123 @ Jan 17 2010, 12:31 AM)
i had an oil change done a couple weeks ago and at the same time they updated the ecu. After the update the car was more responsive but still has poor gas mileage. The dealership said there were no codes. I was going to attemp to change the pvc valve today but its nearly impossible to remove the bolts. I will try it again another day. I am now getting around 530kms a tank. The car is feels sluggish and the other day the jerked a couple times during a hard acceration from start.[/b]
Cold weather would account for poor gas mileage. Also, the gas stations have winter additives to prevent freezing and w/e else and that too accounts for lowered mileage.
Mazda 6i Sport (Hatch, Onyx Black, 15% tint) 2007 - 5 Speed Manual Trans. MT-90 Oil
My Mods:
- Turbo Charged.
Polish_Eagle is offline
post #10 of 17 (permalink) Old 01-17-2010, 03:49 PM Thread Starter
it could be because of the winter gas, winter tires, colder weather but i have been experiencing poor mpg since september.
mahzda6 is offline
