I want to reset the ECU in my 2004 mazda 6 but when i disconnect the battery terminals there is no change to the rpm's when i start the car nor when i drive for a bit. The rpm's used to go crazy when i disconnected the battery but no longer. Any ideas why?
cheers. |
Disconnecting the battery will reset the ECU.
Sometimes mine runs like crap and almost stalls if the AC is on right after reconnecting the battery. But then other times it runs fine.
06 6 I| Xm Radio|Stubby Antenna|Silverstar turn Signal bulbs (Front)|6 1/2 speakers in front door|6 x 8 in rear|Wing Spoiler|Black OE Tail lights|4 Brake light mod|Side markers converted to flash|18 x 7.5 MB Boost rims|Remote Start|LED Map and Door lights|Sport Grill|Auto Dimming Mirror| MS Springs| JDM Visors| K & N SRI|Sony HU|12 in. Infinity Sub @ 400 RMS|Removed Door moldings| Car Pics |
#4 (permalink) | |
QUOTE (Mojar7070 @ Oct 19 2009, 04:13 PM)
LMFAOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
ko4 2 GT3076 BIG POWAAA |
#5 (permalink) | |
I just disconnect the battery, wait few minutes and reconnect it
2004 MAZDA 6S 5 DOOR HATCHBACK,STEEL GRAY, ATX KNN CAI, MAGNAFLOW EXHAUST TRUECOOL LPD TRANNY COOLER EVOKE 17X7 GUN METAL RIMS, 225/45/17 ZR NEXEN N3000 TIRES |
You have to wait a full minute for reserve power to drain. However, ECU takes 10 minutes doesn't it?
All I know is most of the crap I do takes more than 10 minutes anyway so its a guaranteed reset.
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune |
#7 (permalink) | |
QUOTE (ttshark @ Oct 21 2009, 07:29 AM)
I was actually thinking of keeping the key/ignition in ON position to make sure all residual power is gone but I'm not sure if there's a drawback in doing that. what do you think? coz if we disconnect the battery while everything's off there's nothing to use up the remaining power not like when the system is on then disconnect it, it will surely eat up whatever's left...... am I making sense?????
#8 (permalink) | |
QUOTE (seigfredm @ Oct 21 2009, 01:40 PM)
You see, this is why some of the shop manuals tell the technician to step on the brake to discharge any remaining voltage from the ECU capacitors...
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now... Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
#9 (permalink) | |
QUOTE (FORZDA 1 @ Oct 21 2009, 10:45 AM)
#10 (permalink) | |
QUOTE (Mojar7070 @ Oct 21 2009, 10:56 AM)
there's no stupid or crazy questions only stupid answers so the shop manual actually instructs the tech to step on the brakes, all the while I thought when you disconnect the battery none of the circuits will close. I guess I have to reset my ECU again, the proper way. What do you think about leaving the ignition ON then disconnect?
