Hi Guys,
I've replaced my front 3 spark plugs easily. Now on to the rear. I am having the most trouble with the single right hand most (when facing the car) black clip that holds the wire harness to the IM. I am talking about the black molded piece all the way on the right. I've got everything else off..this is holding me back. Any tips/tricks would be appreciated. Thanks [attachment=44023:harness_to_im_clip.JPG] |
Groaned at 6 Times in 6 Posts
Try using a flathead screwdriver to separate the front part of the box that's facing you from the main body. Then pull the box up and out. |
Mine ('05) was simply a Christmas tree plug that I pushed out with a screwdriver. Others were tab that I un-clipped.
Oh, and CLEAN YOUR FREAKIN' ENGINE!
Some see the glass as half-full. Some see the glass as half-empty. I see the glass as needing a coaster. 2005 6S wagon: MazdaSpeed springs / Tokico HP shocks / MazdaSpeed sway bars / Racing Beat end links / GTSpec Trailing Braces / MazdaSpeed CAI / EGR mod / Racing Beat exhaust / Street Unit engine mount / switching to StopTech braided lines / Hawk HPS pads / B&M tranny cooler - Inline tranny filter - Redline D4 fluid / Mazda iPod adapter - CX-7 antenna / Hella FF50 lights-----Need to be getting in gear on installing: MSDS headers & Magnaflow cat; lightweight pulleys----- Considering-- Fluidamper; oil cooler |
