I had a problem with my throttle body and I need a new one, I also need a new MAF sensor for a 03 Mazda6 Sedan.
Do you guys know a good place where I can get them cheap? or anywhere at all? Also can you guys give me the sizes, I realy dont know which fit my car 2.0, 2.3, or 3.0 difference? 60mm? Thanks. |
i would start by saying what car you have, be it 4cyl or V6? at that point, you still have your tb? what's wrong with it?
there are plenty of places to go to get factory ones, Mazmart might have a used one for you, Finishlineperfromance has decent prices on new ones, or hit up twowheelin (cordova motorsports) and he can hook you up with an optimized one while your at it?
Its a V6. I took it to the Mazda agency today and they told me it needed a Throttle body replacement. Usually when I turn on the car
I hear a sound like a rattle and the car starts fine. But when I don't hear that rattle (TB) it begins to idle a lot. When it starts idling I open it up clean the tb from the inside with some spay and the MAF sensor then it starts to work again like it gets more oxygen. |
for a optimized TB, go to cordovamotorsports.com or pm twowheelin.
I think front1ine has some as well. For a MAF, try sheldon at mazmart.
Link to the Yellow Submarine [2003 Speed Yellow]... Come join the flickr group! http://flickr.com/groups/atenza/
