Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 2nd Generation (2009-Present) > Engine / Drivetrain
Old 08-30-2009, 12:16 PM   #1 (permalink)
Whos running 6qts. of oil in their 3.7L Duratec? Last OC I ran 5.5qts. of 5w-20M1 for 4K miles and the dipstick started and ending in the middle. Today I changed the oil and added the extra 1/2qt to the fresh 0W30M1 and the dipstick now reads about 3/4. From what I could tell the engine burned a little oil during the 4k OCI so adding the extra should be beneficial all around while still remaining under the "full" reading.
JeepRubicon2k3 is offline   Reply With Quote
Old 09-09-2009, 07:54 AM   #2 (permalink)
chisss's Avatar
Send a message via AIM to chisss Send a message via MSN to chisss
Add whatever the manual says to add.
SELLING EVERYTHING! HERE
chisss is offline   Reply With Quote
Old 11-18-2009, 08:22 PM   #3 (permalink)
i originally added 6 qts the 1st time i changed oil and it was a little overfilled, from my understanding the 3.7 in the 6 uses 5.5qts 5 for the engine and .5 for the oil filter. Maybe im wrong..
2009 Mazda6 S Grand Touring - Brilliant Silver Metallic - Everything but the Nav system
jkmags is offline   Reply With Quote
Old 11-22-2009, 01:35 AM   #4 (permalink)
c-man's Avatar
I've done 8 oil changes now...nothing gets left over. The filter is pretty large.
Chuck's 2003 Hyundai Tiburon GT - Eaton Supercharger and bolt-ons
and 2009 Mazda 6 GT - Auto EXE springs, Rotora BBK, tinted windows, cf engine cover
c-man is offline   Reply With Quote
Old 12-22-2009, 07:25 AM   #5 (permalink)
ran across this,. http://www.mazdausa.com/MusaWeb/pdf/specs_...pecs_MZ6_09.pdf so I guess depending on your oil filter it would be 4.9 plus. The best thing to do would be to fill the oil filter with oil before you put it on and then add 5 quarts of oil as long as this pdf is correct.
John
