Do the new 2.5l engines have canister oil filters or spin-on?
I'm curious if Mazda went back to spin-on, since there were so many issues with the 2.3 canisters being cracked by crap mechanics, etc. |
#2 (permalink) | |
QUOTE (kikboxr1 @ Feb 7 2009, 08:55 PM)
I'm getting the oil changed Fri.I'll let you know...............
2009 Onyx GT-I4 Loaded except Navi Tint (35% all around) Remote Start 2005 GS-V6 (traded in) |
#3 (permalink) | |
QUOTE (kikboxr1 @ Feb 7 2009, 05:55 PM)
I've no experience with Mazda's canister filter on my 2.5L 4 cyl. , and haven't yet crawled under to examine it. Before I change the filter, does anyone have thoughts about what to look for / be careful of etc.??
Thanks
'09 Mazda6 i Touring, Kona Blue Mica, 5 spd. auto, convenience pkg. '08 Mazda Miata MX5, GT, True Red, 6 spd. manual, PRHT, Suspension & Premium pkgs, debadged, Exgel knee pad, AuxMod '05 Red, Ducati Multistrada 1000 DS '01 Inferno Red, PT Cruiser, Eibachs/Konis |
eh. the 3.7 V6 has a easy to get to spin off. I changed the oil w/o jacking the car or lifting it in anyway
The Xbox 360, however, has set out to put all previous console gremlins to shame. Among the many 360s in IGN offices and homes the failure rate has been staggering and the replacement process long and aggravating. - IGN, April 28, 2006 2009 Mazda 6s Touring - Onyx 2009 Toyota Corolla S - Classic Silver Metallic (Wife's Car)
#6 (permalink) | |
QUOTE (Scorpion @ Apr 8 2009, 12:07 AM)
2009 Mazda6 i GT, Moonroof & Bose Pkg |
#7 (permalink) |
What is the difference between a cartridge filter and a spin off?
Thanks
Nolig 2009 Mazda6 SV 1994 MX-3 BPT |
#8 (permalink) | |
QUOTE (Nolig 6 09 @ Apr 16 2009, 01:35 PM)
Spin on filter is what you're probably used to seeing: It (the entire filtering apparatus) literally spins on and off and is 1 complete piece....remove and replace the entire unit. Cartridge is a little different: you remove the outer casing (which is reused indefinitely) and instead replace the inner filter cartridge with each oil change. Problem with doing the cartridge yourself is you need a special tool to do it...where a spin on usually just needs a strap wrench or something similar
2003 Performance White 6s MTX, CPE CAI MAF-CI, Xtec 5000K HIDs, Superwhite LEDs, TB bypass, EGR mod, Iridium NGKs, 25% tint, clear sidemarkers w/ turn signal mod, brakelight mod, SU MM, MazdaSpeed Short Throw Shifter, Custom Exhaust: 12" glass pak resonator and axle-back Str8s, Flat Black painted bezels, Exedy Stage 1 clutch and Fidanza Flywheel, ceramic pads, Redline MT-90, Mobil-1 0W-20 and Mobil-1 Mercon V PS fluid |
#9 (permalink) |
I'm confused - I admit that's not always hard to do... But, when I look in several places / catalogs all I find is a reference to a replacement cartridge, Not the entire spin-off assembly like everything else I've owned since the late 50s.
I just went out and put it on the ramps, then rolled underneath w/ the creeper. If I'm looking in the right place, that Ain't no "spin off"! When looking up through the large hole in the splash shield, I see a black composit "cap" that has a white metal plug in the center. This is on a metal housing. Both the plug and "cap" have torque specs. on them. So... Am I looking in the right place? If I am looking in the right place, anyone out there w/ experience w/ this type filter on this engine? Thanks
#10 (permalink) | |
QUOTE (Scorpion @ Apr 16 2009, 07:14 PM)
