Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain
Old 04-09-2008, 10:23 AM   #1 (permalink)
DjLethal6's Avatar
So I just replaced my spark plugs with the Pulsar from the GreatNY group buy and am thinking about replacing the spark plug wires as well.
My question is, what kind of performance gains should I expect from replacing the wires?
Should I be worried about replacing them at 60K miles?
What are the best kind (NGK, Pulsar, Magnecor etc)?
Where can I get them?
'03 6i MTX (Steel Grey)
Black Racing l CPE l Momo l EBC l JDM l Redline l McCulloch l Toyo l Hollanda l Luminics l PIAA l Freedom Design l Tanabe l RPM l MazdaSpeed l Hawk l DDE l Pulsar l
DjLethal6 is offline   Reply With Quote
Old 04-09-2008, 11:29 AM   #2 (permalink)
twowheelin's Avatar
I wouldn't expect any performance improvement or you will probably be dissapointed, but at 60K new wires certainly wont hurt. The factory wires are a reasonable price and fit perfectly. Not sure what aftermarket wires are available??
03-6i ATX: Hawk ceramic pads, SS lines, PowerSlot Rotors, Tanabe-NFs+Konis, Kosei K1-TS, Spin On Conversion, Custom CAI/MAF, 2 1/4" Exhaust, Optimized TB, Adjustable Fan Controller CordovaMotorsports.com (An RPM Customer!)
twowheelin is offline   Reply With Quote
Old 04-09-2008, 12:04 PM   #3 (permalink)
DjLethal6's Avatar
The only aftermarket I've seen so far have been the Magnecor and I figured since our OEM plugs are NGK they would manufacture the wires as well.,
Old 04-10-2008, 08:25 AM   #4 (permalink)
nashirak's Avatar
Send a message via AIM to nashirak
As twowheelin said, don't expect much or any gain.
The only way you'll really feel any gain is if the current wires are bad. If they are so worn out that you are starting to run BADLY, then replacing the wires will have a noticeable effect. Otherwise, not really.
I'm not sure what brands are all out right now. But as mentioned, the OEM's should work fine for you.
2006 Jeep Wrangler Unlimited, 4.0 I-6, 6sp MTX, silver w/black tops. The new hotness.
<strike>2004 Glacier Silver 6s MTX Sport</strike> - Dead and gone
Check out my previous Garage
Best Wishes, Hammer Down, Enjoy the ride....Will
nashirak is offline   Reply With Quote
Old 06-22-2008, 10:02 PM   #5 (permalink)
Kid Cromer's Avatar
Do any of you have any further information regarding comparing the OEM wires vs. aftermarket wires like Magnecor for example? I was looking at the Magnecor Blues (8mm: 40453) in particular. Do you think there is any advantage/gain going with these vs. OEM or would it be more a waste of money than anything else?
2003 Glacier Silver 6i ATX, OEM Sport Grille (Blacked-Out), Eibach Pro-Kit, 18" ALT X-Factors (Carbon Black), Bridgestone Potenza RE050A XL 215/45/18 Tires, StopTech Slotted Front & Rear Rotors, Carbotech Bobcat Brake Pads, Anzo Clear Side Markers (Signal Marker Mod), Valiant Style Eyelids (RPM), AuxMod, 12" Kicker Subwoofer, Profile 600W Amp
On Ice: 17" OEM Wheels & Tires
Kid Cromer is offline   Reply With Quote
Old 06-22-2008, 11:19 PM   #6 (permalink)
The Great NY's Avatar
being that you have a 6i.........im not to familiar with you factory wire size. typically the bigger the wire you go, the less resistance, and that results into a lower power loss to the plug for the spark.
OEM's are good. but honestly if you wanna get into your ignition. try upgrading and transfering your car to "Coil on PLug" ignition.
Mr Tea.............IIRC did this to his 4 banger, shoot him a pm.
but if you dont want to go that route then just stay OEM, because like they said above, the gains arent there and if they are you wont tell. so its probably not worth switching to aftermarket.
Punisher 6 - Twin Turbo - 305whp, 303wtq @ 6.5psi - HATE IT OR LOVE IT, THIS IS JUST THE TIP OF THE ICEBERG
"Nuthin To Prove, Just Watch Me Groove"
COME OUT AND REP YOUR 6 FAMILY!!!!
The Great NY is offline   Reply With Quote
Old 06-22-2008, 11:36 PM   #7 (permalink)
MrTea's Avatar
the butt dyno MIGHT say it's a smoother idle, and there was about 500rpm up top (just before redline) that looked smoother with wires on the dyno...but not "better".
if you have to replace them, you might wanna just pick up the Magnecore's. they will look a lot better (if you don't use that dumb beauty cover) than stock, but i wouldn't do it for performance for the hell of it.
Old 07-08-2009, 05:13 PM   #8 (permalink)
Toadster's Avatar
Send a message via ICQ to Toadster Send a message via AIM to Toadster Send a message via MSN to Toadster Send a message via Yahoo to Toadster
wires? i thought we had coilpacks?
2004 Performance White MAZDA6s MTX
Injen CAI | Magnaflow Catback | CP-E MAF-c | 18% Tint | Red Line MT-90
17x7 Kosei TS-1 wheels & ContiSportContact 3 225/45-17
My Mazda6 PICS|Toadster's Website|MySpace
Toadster is offline   Reply With Quote
Old 07-08-2009, 07:31 PM   #9 (permalink)
MrTea's Avatar
we has the OG 6, before the COP's started
Old 11-18-2009, 05:43 PM   #10 (permalink)
speed914's Avatar
Send a message via AIM to speed914
QUOTE (MrTea @ Jul 8 2009, 06:31 PM)
I am just curious if we need to actually replace the wires when we replace the plugs.
The mustangs I had we always replaced the wires when we did the plugs but the stock wires are totally different than the ones I have worked with before.
Any ideas?
2005 Mazda 6i Sport Glacier Silver ATX
Apexcone 6000k HIDs, PIAA 7500K Spark Blue H3, F5 Fujita Intake, Remote Car Starter, Lotek Gauge Pod, ProSport Premium Series Oil Pressure and Oil Temp Gauge, ProSport Performance Air/Fuel Ratio Gauge, ScanGauge II, CPE battery tray, Odyssey 680, Tein Hood Dampers, grounding kit, clear side markers, Mazda3 2.0l Spin-on Oil Filter conversion, G2Performance Caliper paint, All weather mats, ALL hyper white LEDs, stubby antenna
speed914 is offline   Reply With Quote
