Cleaning the throttle body - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 04-17-2007, 06:45 PM Thread Starter
zoomzoomfan's Avatar
I picked up some TB cleaner/lubricant from my local autoparts shop and figured I'd give the TB a quick spray. Figured it'd never been touched before by anyone.
Anyways... instructions on the spray can:
1. With engine off, remove boot at TB
2. Start engine
3. With engine running, spray cleaner into TB
4. Let engine run until it idles smoothly
5. Drive immediately
After performing step 1, I found that the engine wouldn't stay alive with the TB boot off. So, instead, I sprayed TB cleaner into the TB against a closed throttle plate and put the boot back on and started the car. Car started up an bit rough but settled down quickly and idled smoothly. Went for a quick drive right afterwards.
Has anyone attempted a TB clean? If so, how'd you do it?
2004 Mazda6 GT Hatch I4 MTX
zoomzoomfan is offline
post #2 of 9 (permalink) Old 04-17-2007, 06:50 PM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
I used a toothbrush on the TB and sprayed the cleaner and scrubbed away.I then used a clean shop rag and wiped up the excess fluid and the grime.It fired right up after that.
2010 F-150
1990 F-150
djquik1 is offline
post #3 of 9 (permalink) Old 04-18-2007, 06:23 PM
twowheelin's Avatar
The instructions are bad for most modern cars actually. When you remove the 'boot', you're removing the MAF sensor from measuring the air flow into the engine. That might explain why your car wouldn't stay running. If you have the accordian tube removed You can push on the bottom of the plate and it will rotate open if you want to clean behind the plate. I'm not sure there is much benefit to doing this unless you have enough carbon/gunk to actually interfere with the closing of the plate. The plate will spring closed when you let go.
Here is an open TB plate... (Clean too )
Hawk ceramic pads, SS lines, PowerSlot Rotors, Tanabe-NFs+Konis, Kosei K1-TS, Spin On Conversion,
, 2 1/4" Exhaust,
, Adjustable Fan Controller
(An
twowheelin is offline
post #4 of 9 (permalink) Old 05-16-2007, 10:31 AM
Just open your airbox and spray it in that way
owenUK is offline
post #5 of 9 (permalink) Old 04-22-2012, 01:34 PM
pogipants's Avatar
I cleaned my MAF sensor today and decided to clean my throttle body too. Look what i found!
So gross. In my Integra I had a lever outside the TB that I could tap to open and close the butterfly thing, do we have one on the 6?
2003 Onyx Black Mazda 6i MT
Megan Springs - Tokico Blues - 35% front, 20% rear - Protege 16" wheels - Blacked Out Mustache and Front Emblem - Injen CAI/SRI - LEDGlow Interior Lights
pogipants is offline
post #6 of 9 (permalink) Old 04-22-2012, 01:45 PM
Danger_Dorn's Avatar
No we don't have one. You have to push on the plate
2009 Mazda 6 S 4 Cyl 2.5L, Spectre SR CAI, Bosche +4 Spark Plugs, Painted Engine Panels, 35% Tint, Dunlop Signiture Tires, Tinted Taillights, 70k Miles. Total Investment: About $1000.00
Danger_Dorn is offline
post #7 of 9 (permalink) Old 04-27-2012, 06:12 PM
better to remove it and clean it thru only would take 30mins
i usually do it every 10000 miles
fitos is offline
post #8 of 9 (permalink) Old 02-04-2016, 12:43 PM
can you explain how to remove the TB? i cant find a DIY guide... Thanks!
bryandpv is offline
post #9 of 9 (permalink) Old 08-08-2016, 07:41 PM
zbillster's Avatar
FLUID's blog: Mazda 6?How to clean throttle body
2006 onyx black base 6i 5-speed manual with 18" RX-8 wheels.
Racing Beat springs/swaybars. Protege shift knob (adds 2 hp!).
zbillster is offline
