CAI and car washes. Engine on or off? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain
New User? Register
View Poll Results: Engine on or off during a car wash?
Off 12 42.86%
On 16 57.14%
Voters: 28. You may not vote on this poll
Old 12-09-2006, 05:14 PM   #1 (permalink)
daztd's Avatar
Groaned at 8 Times in 8 Posts
Quoted: 15 Post(s)
Thumbs up
This is a general question about CAI and automatic car washes. Do u guys turn off the engine or leave it running, especially if it does the under carriage.
Poll question(Look up )
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica
DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
daztd is offline   Reply With Quote
Old 12-10-2006, 10:40 AM   #2 (permalink)
daztd's Avatar
Quoted: 15 Post(s)
Post
Does anyone use a hydro shield cover over the air filter?
Old 12-10-2006, 10:45 AM   #3 (permalink)
HedsIc's Avatar
Send a message via Yahoo to HedsIc
I keep mine on when I use the autowash's. BUt I try to stay away from them as much as posible as they are basically a waste of money except in the winter when it's to cold to get out and wash the salt and crap off..
I havn't had a problem in about 6 months or more of having the CPE MFACI. and I removed all of the grill inserts so it is wide open to my airfilter...
Any water that isn't first absorbed by the intake still has to travel all the way through the pipe. THEN on top o fthat it still has to go through extremely high heat. Which will evaporate ane burn off any water.
Then even after that, you still need enough left to cause any damage. It's not going to happen unless you are the very few unlucky people.
I won't say something bad CAN'T happen. but the odds are for you that it won't. The problem comes wen you actually insert the hole filter in to water which gives it suction to actually force up large amounts of air.. when then you are screwd
HedsIc is offline   Reply With Quote
Old 12-10-2006, 10:46 AM   #4 (permalink)
I never really gave it much thought, but I've done both. Mostly keep it runnin', but on Friday I turned it off. Yes, it has an under carriage wash and no on the hydro cover.
Sig..... top gear87 bitched so I fixed it... http://forum.mazda6club.com/index.php?showtopic=77706 post# 9...
The infamous screen name windshield banner that mazda6club.com just wasn't ready for... http://forum.mazda6club.com/index.php?showtopic=77697 2850...
05 6I ATX/ 09-07-07 Dyno'd at 154 WHP/
wmoore@mar.med.navy.mil is offline   Reply With Quote
Old 12-10-2006, 10:51 AM   #5 (permalink)
M6IWKU's Avatar
I always leave mine running because its not high standing water and thats when problems can occur. I also have the hydro shield which works really well. I once held the filter with the hydroshiled on up against a garden hose going full blast and not a drop of water got in, so in short I don't worry about car washes...
M6IWKU is offline   Reply With Quote
Old 12-10-2006, 10:57 AM   #6 (permalink)
Rydawg7926's Avatar
Thats a bold strategy, haha. But I only had one problem at night during a flash flood i ran through really deep water that I couldnt see and the intake sucked up some water. However, I got really lucky and made it home than let it sit overnight and ran it at high RPMS and everything has been alright since.
"Alcohol, the cause of, and solution to all of life's problems!"
Rydawg7926 is offline   Reply With Quote
Old 12-10-2006, 11:02 AM   #7 (permalink)
M6IWKU's Avatar
haha The filter was off the intake and in my hand when I sprayed it if thats why you say thats not a good strategy.
Old 12-10-2006, 02:30 PM   #8 (permalink)
HedsIc's Avatar
If you drove through a puddle big enough that allowed the intake to actually be submersed and suck up water in to it. You wouldn't have made it home. Hydrolock happens right away. not gradually over time..
You probably just got the filter wet from splashing water but didn't get anything more then a small fine mist sucked up that burned off. Not actaully sucking any water up in to it though.
Old 12-10-2006, 02:52 PM   #9 (permalink)
I know AEM an d some others sells a CAI bypass valve...Looks like a doughnut and let the enige suck air throught the valve (place higher up in the enigne bay) when the pressure get too great to suck through the filter ie. if your in a deep puddle!
gonna look into gettin one of these for myslef!
ps. i keep the engine running @ the carwash!
2005 Mazda6 S MTX Hatch Lapis Blue, Black leather, moonroof, Bose Audio, Auto Climate Control, Homelink,
Eating more of my money every Week!
<div align="center">RkeyTek
<div align="center">MetalArchitect.com
Sluty6 is offline   Reply With Quote
Old 12-10-2006, 03:21 PM   #10 (permalink)
Where did you find this? It doesn't sound like a good investment unless you plan on modding your 6 into a hydro craft. Driving through puddles? What ever happened to just going around the lake and not into one? CAIs are nothing to be afraid of. Just use common sense.
