Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain
Old 10-25-2005, 12:53 PM   #1 (permalink)
batmobile018's Avatar
Send a message via AIM to batmobile018
While installing the cp-e intake, the long plastic tube that comes from the valve cover and connects the hose to the bottom of the intake broke. Does anyone know what's the actual name or part number so i can order it. btw heres some pics i got from mazda6tech to help describe what im looking for. The part im talkin about is circled green. thanks
eddie
batmobile018 is offline   Reply With Quote
Old 10-25-2005, 02:02 PM   #2 (permalink)
speedracer6's Avatar
eddie
[snapback]542280[/snapback]
It's the PCV breather connection. Where did it break? All you really need is an open connection from that valve cover fitting to the filtered air fitting. You can just connect the two broken pieces with a tight fitting piece of rubber hose and you may want to clamp the hose in place. Be sure that it won't collapse with heat or you'll put your crankcase under vacuum and suck the seals in.
speedracer6 is offline   Reply With Quote
Old 10-25-2005, 04:13 PM   #3 (permalink)
Send a message via AIM to chambers7867 Send a message via Yahoo to chambers7867
or u can be smart and get a crankcase filter and find a way to block off air to that hole inside your intake! it's a 5.00 fix!
MAZDA 6i 2.3l: Magnaflow exhaust, InJen intake, Cpe battery tray, Oddssey lightweight battery, Nitrous Express efi wet kit, Nos bottle warmer, Nos bottle Blanket, MR. Racing nitrous plate, Zex purge kit, AutoMeter Nitrous, Tranny, Air/fuel, Volt gauge (sportscomp) Lotek 3 gauge pod, MoMo Duke shiftknob, MoMo endurance shiftboot, Powdercoated valve cover, Powdercoated wheels, Rotra rotors, BenDix brake pads, Stainless steel brake lines, stainless steel fuel lines, MR. Racing fuel rail, Autometer fuel pressure gauge, custom strut bar, 10% tint all around, tinted taillights and sidelights, Planet audio 5x7 speakers all around, Jvc Exad dvd player headunit. carbon fiber hood.
chambers7867 is offline   Reply With Quote
Old 10-25-2005, 06:33 PM   #4 (permalink)
[snapback]542462[/snapback]
I assume you mean the intake plumbing and not the intake manifold.
Old 10-26-2005, 12:57 AM   #5 (permalink)
well it broke near the engine cover. So, is it called pvc breather hose??? (the plastic tube is about a foot and half long.)
Old 10-26-2005, 09:35 AM   #6 (permalink)
[snapback]542888[/snapback]
Yes, and unless you broke the fitting in the valve cover you can repair it with some hose.
Old 10-27-2009, 08:57 PM   #7 (permalink)
Noob here,
Talk about bringing one back from the dead. That pcv breather hose shown in the picture is snapped off at my accordian tube. Would that cause my car to all of a sudden start stumbling hard?
It originally had a stumble but nothing like it is now. I took it to pep boys to get a tune up, and they called me back and told me that it had broke off and they wouldn't do the tune as that should fix my stumbling problem. They also said that whoever worked on my car before already broke it and superglued it back on. The dealer says I need to buy a new intake for 500 bucks. No way am I paying that much. So I guess I have two questions.
Will that cause me to stumble/misfire(I am throwing a code now, but wasn't before, cyl 5#). And whose leg do I have to hump for a stock replacement tube and accordian for cheap ?
Sac6 is offline   Reply With Quote
