Transmission Cost - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 09-20-2004, 05:52 PM Thread Starter
It looks that everyone is worring that the transmission on 2003/4 6s ATX might fail early. What's the approximate cost to replace it, parts and labor? Would factory warrnaty cover it? Would extended warranty cover it (I believe Mazda said it covers everything)?
drongar is offline
post #2 of 8 (permalink) Old 09-20-2004, 06:12 PM
If a transmission were to fail then, yes, Mazda would cover it under the factory standard and the extended warranty. But it's exceedingly rare for a transmission to fail. Even horribly crappy ones will last well over 100K (I'm talking as a whole, every make will have some bad ones that will fail anywhere in the middle) in which case no warranty will be in effect.
Sigma is offline
post #3 of 8 (permalink) Old 09-20-2004, 08:16 PM
atom44wat's Avatar
I am on my second tranny. Mine failed at 42,000 and was replaced under warranty. I gather that at 90 dollars an hour for labor plus the tranny I was looking at almost a $4,000 job. I don't know what the labor rates are at your dealer but that would effect cost also.
Mine went bad due to a faulty solenoid inside the tranny.
atom44wat is offline
post #4 of 8 (permalink) Old 09-21-2004, 10:20 AM
Thats funny, thats over double the labor rate at my regular mechanic.
GreenNuggs is offline
post #5 of 8 (permalink) Old 09-22-2004, 02:16 AM
MazdaManM6's Avatar
Originally posted by Sigma@Sep 20 2004, 05:12 PM
If a transmission were to fail then, yes, Mazda would cover it under the factory standard and the extended warranty.* But it's exceedingly rare for a transmission to fail.* Even horribly crappy ones will last well over 100K (I'm talking as a whole, every make will have some bad ones that will fail anywhere in the middle) in which case no warranty will be in effect.
[snapback]305498[/snapback]
Very true, some will inevitably fail however there haven't been enough failures so far to start worrying. When we start seeing failure after failure before 50k miles then it's time to start thinking about replacement costs. My 626 had a crappy cd4e and it still lasted for about 70k miles. Some even managed to push it further so it's still too early to tell. Barring any electrical/computer problems we should expect to see service well beyond the 100k mark with a tranny cooler and a good fluid service interval.
2003 Onyx Black 6s atx, B&M 13,000 btu tranny cooler, AEM cai, AEM Dryflow filter, Fumoto valve, CP-E Wishbone mount, Throttle Body coolant bypassed......
MazdaManM6 is offline
post #6 of 8 (permalink) Old 09-22-2004, 01:06 PM
nashirak's Avatar
Send a message via AIM to nashirak
Warranty should cover any kind of all out failure like that. If a solenoid or pressure switch goes out or something to that effect, then it's fault of the builder. Especially inside 50k.
2006 Jeep Wrangler Unlimited, 4.0 I-6, 6sp MTX, silver w/black tops. The new hotness.
<strike>2004 Glacier Silver 6s MTX Sport</strike> - Dead and gone
Best Wishes, Hammer Down, Enjoy the ride....Will
nashirak is offline
post #7 of 8 (permalink) Old 09-23-2004, 12:13 AM
I am considering buying the extended warranty because I have begun to experience some problems with my '04 6s. It has 15k on it. Surely I could decide when I have 49998 on it right?
2004 Mazda 6s MTX
fly757 is offline
post #8 of 8 (permalink) Old 09-23-2004, 12:48 AM
atom44wat's Avatar
Stay on topic or this topic will be locked!!
