Battery stays on after I turn ignition off - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 44 (permalink) Old 06-07-2015, 12:55 PM Thread Starter
Hello all,
I've got a 2014 touring and only a few days ago when I park and hit the ignition switch my battery won't turn off. The radio stays on and I can work the cabin lights but the AC turns off. I've tried over and over again depressing the brakes and turning the car on and off and it won't work. I've found if I drove the car about 30 seconds and try again I have success. Is anyone else having a similar issue? I've gone through most of the forum and haven't seen anything similar. Does anyone know a solution? This is driving me nuts. Thanks!
Ointhepmp is offline
post #2 of 44 (permalink) Old 06-07-2015, 02:57 PM
Jerrycobra's Avatar
Quoted: 304 Post(s)
disconnect your battery on the negative terminal for 5 minutes and see if the issue goes away. Usually that resets everything and fixes the electrical bugs the car runs into.
2014 Mazda 6 Touring Liquid Silver
[ OVT 91 octane tune ][ CS Power Series SRI+Airbox ][ Racing Beat Axleback ][Paddle Shift retrofit][ Morimoto XB35 35w 5000k HID lows ][ LED interior lights and plate lights ][ 3M FX HP Tint ][ Dipped rims and dipped trim ]
Jerrycobra is offline
post #3 of 44 (permalink) Old 06-09-2015, 11:30 AM
Daveandthe6's Avatar
Quoted: 48 Post(s)
Do you have a manual nor automatic?
Daveandthe6 is offline
post #4 of 44 (permalink) Old 06-24-2015, 07:49 PM
SoCal9erfan1's Avatar
Originally Posted by Ointhepmp View Post
Hello all,
OMG!!!!!!! I thought i was the only one with that issue sometimes takes me up to 7-8 minutes before it will shut down has anyone else has this issue and know the answer? I've taken my car to dealer 3 times and they still cant fix it someone help please
SoCal9erfan1 is offline
post #5 of 44 (permalink) Old 06-24-2015, 10:41 PM
Quoted: 91 Post(s)
Groans: 7
This is going to sound really stupid, but... have you tried just opening the driver's door when this happens? Some of the electical accessories (like the windows, for example) continue to work until you open the door.
blitzoid is offline
post #6 of 44 (permalink) Old 06-25-2015, 11:39 PM
eyedocorlando's Avatar
Quoted: 87 Post(s)
Groaned at 5 Times in 3 Posts
Are you shutting the car down in Neutral instead of Park? If so, things will stay on ACC.
eyedocorlando is offline
The Following User Says Thank You to eyedocorlando For This Useful Post:
OCTOGONPC (07-15-2017)
post #7 of 44 (permalink) Old 06-26-2015, 07:28 AM
FusionGT's Avatar
Quoted: 355 Post(s)
Groans: 11
That's exactly what I was thinking, since I've done it before... Haha.
Has your Mazda ever climbed a mountain?
FusionGT is offline
post #8 of 44 (permalink) Old 08-03-2015, 09:13 PM Thread Starter
Still having the issue. Just started again last week, I've been trying to shut my car off for 30 minutes
post #9 of 44 (permalink) Old 01-13-2016, 11:05 AM
2014 Mazda 6, same issue. After I put the car in Park, hit the ignition button, the engine turns off, but the car goes into Aux Mode.. radio works, and car beeps if the door is open. I put my foot back on the break, move the shifter out of park and back into park, press the ignition button, and it turns off. Its almost like the shifter isn't going all the way into Park. Not sure the proper name for "shifter".
Anyone else?
kbabe is offline
post #10 of 44 (permalink) Old 02-01-2016, 11:29 AM
I've been having the same issue for at least around 6 months now with my 2014 6. I've been periodically looking in the forum(s) for answers, and this is the first time I've found anything.
The way I fix it is to pull the shifter all the way to the right (never leaving 'Park') and then letting it pop back to the left. After that, I turn the car back on (no ignition - foot off brake) and then try to turn it off again... hit the "On" button twice, basically. This resolves the issue 100% of the time for me, though it sometimes takes repeating the steps once or twice more. I can also state that this happens every day on almost every drive. Rare to have it NOT happen, honestly.
When I asked about it at the dealer, they seemed perplexed and also had me try some other things I see recommended in this thread while I was there... opening the door, rolling down the driver side window, etc. On that day, we did also have success with the "open door" method, but I haven't tried that since then, given the rate of success with the "shifter" method.
I'm going to try disconnecting the battery to reset things, and see what I get (though I think we did that at the dealership as well).
Will update as soon as I can...
Sheree G likes this.
jl4strng is offline
The Following User Says Thank You to jl4strng For This Useful Post:
Sheree G (03-22-2018)
