Bluetooth (& Handsfree system), Pandora, and USB not working - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 89 (permalink) Old 11-21-2013, 10:07 PM
I had the same issue tonight on my 2014 Mazda6 that's less than 2 weeks old! This fix worked just fine but I had to reset every station preset and quick dial phone number in the system. I love my new car but I agree this system is very clunky and problematic. Thank you danstheman7 for the petition, I signed it and hope it does some good for all of us!
VJDiAngelo is offline
post #12 of 89 (permalink) Old 12-10-2013, 03:48 PM
Removing the negative battery terminal for a few minutes fixed the issue in my new Mazda 6. Too bad this happened within the first 2 weeks of ownership. Hopefully not an omen of things to come with this car.
jcook is offline
post #13 of 89 (permalink) Old 12-13-2013, 08:14 AM
Sideways the Seven's Avatar
Quoted: 407 Post(s)
I may have to do this and sign the petition.
-St7
-Brandon
2003 Infiniti M45
1981 Chevrolet Silverado RCLB (heh, try me)
Sideways the Seven is offline
post #14 of 89 (permalink) Old 12-13-2013, 03:53 PM
Quoted: 8 Post(s)
Thank you for the recommendation. Unplugging the negative battery terminal fixed my bluetooth, pandora, usb issues for me.
Geaux is offline
post #15 of 89 (permalink) Old 01-09-2014, 08:48 AM
Dave P
Guest
Posts: n/a
Quoted: Post(s)
I've just had the problem of the blue tooth phone system failing to connect on my new Mazda 6. It was working, then stopped. No phone functions were available.
I saw elsewhere on the web the method of disconnecting and reconnecting the battery to reset the Audio unit. Instead, with the ignition off, I took out the 3 audio system fuses (No 38,43,44). When I put them back in and switched on the ignition the phone system was working again.
post #16 of 89 (permalink) Old 01-22-2014, 09:42 AM
Indy51
Guest
Posts: n/a
Quoted: Post(s)
I also have a 2014 Mazda 6, about 2 mos old. I have same symptoms as MoeMM. Will also try disconnecting the battery.
post #17 of 89 (permalink) Old 02-16-2014, 09:53 PM
Day 2 of owning my Mazda 6 and I am having this issue. Cannot select Phone, Pandora, USB or Bluetooth on my screen.
Very frustrating. Will be going to the dealership after work tomorrow. Is the battery fix the only "fix" currently available?
oklahoman is offline
post #18 of 89 (permalink) Old 02-16-2014, 10:18 PM
Mine was like that when I first picked it up from the dealership. They were all scratching their heads. I took it home and disconnected the negative battery cable and it fixed it. Too bad I've had to do this several times now.
CountryCruiser is offline
post #19 of 89 (permalink) Old 02-17-2014, 07:48 PM
Just got back from my dealer. They had not experience this issue yet, but was somewhat aware of the issue from a monthly service call. Ordering new bluetooth part that is supposed to fix this issue. Will report back once that is installed next Monday.
post #20 of 89 (permalink) Old 02-21-2014, 12:32 AM
Eunice
Guest
Posts: n/a
Quoted: Post(s)
I had the same issue happened twice and I've only had the Mazda CX5 2014 for four months. First time I took it to the dealer and they fixed it. Second time, my husband fixed it using these instructions (reset the stereo by unplugging the car battery but you only need to do the negative connector).
2014 Mazda6 Bluetooth Stopped Working - RoundelMike.com
I hope Mazda figures out what's going on with this issue and have recall to fix the root cause.
