Bose head unit works but no sound:(??? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 11-29-2011, 02:22 PM Thread Starter
pbmattc's Avatar
So my Bose sound isn't working I checked the relay and the audio fuse both fine, the head unit and all works except no sound I checked the speakers to see if they were blown but their not.....I haven't touched any of the wires what's wrong?
pbmattc is offline
post #2 of 6 (permalink) Old 12-20-2011, 08:24 PM
it happens to me as well. Everything looks fine but no sound. So I ordered a used BOSE amp from ebay. After the swap, problem solved. (the amp is under the front passenger seat)
mocha is offline
post #3 of 6 (permalink) Old 03-18-2012, 09:01 PM Thread Starter
pbmattc's Avatar
I bought a new amp replaced it but still no sound is it possible that the headunit can display but something is blown in the headunit
pbmattc is offline
post #4 of 6 (permalink) Old 06-18-2018, 01:06 AM
I am currently in the same exact position with my car producing no sound but the head unit appears to be working. I've replaced my Bose amp with one I purchased on eBay to no avail. Did you ever get this problem fixed?
spearoid is offline
post #5 of 6 (permalink) Old 06-18-2018, 07:02 PM
Quoted: 50 Post(s)
How did you check to see if the speakers were blown? If one of the speakers are blown or wires grounding out it can send the amp into protect mode. I would try as worst case scenario disconnecting all speakers and plugging them up one by one until the sound goes out. This is one method.
audiofreak19 is offline
post #6 of 6 (permalink) Old 06-28-2018, 04:05 PM
I had this exact same problem and the information available on the internet is surprisingly sparse for this issue, despite it being fairly common. Strangely, it was a thread for the Millenia where I found the clues to the source of the problem.
The issue is, apparently, the head unit, at some point starts to fail to send a low amp signal to the Bose Relay under the hood...and once this signal fails to be sent, the relay never switches, and the Bose amp never powers on. The strange thing is, this failure can be intermittent as mine was. I went three weeks with no audio, then all of the sudden it started working again. This is how I knew for sure that A) no fuses were blown and B) my amp wasn't toast.
Under the hood, you can remove the not-broken relay for the Bose system and place a paperclip on the two silver contacts, completing the circuit to power your amp. If your issue is the same as mine you'll have sound as soon as you turn your stereo on. I suppose it's possible you just have a bad relay, but I swapped mine with a neighboring good relay, and nothing changed.
I haven't yet implemented a permanent work-around for this failure of the head unit's, but there are definitely many ways to work around this. I haven't decided yet which way I want to go. I currently have a 10 amp fuse jammed into the silver contacts, meaning my amp is technically always on But I have sound back!!
spearoid is offline
