DIY: Headlight lens replacement Mazda 6 2007 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 6Likes
post #1 of 12 (permalink) Old 08-25-2017, 02:11 PM Thread Starter
Vader6's Avatar
Hi fellow 6ers,
I recently replaced my headlight lenses, and would like to share with you my success. After much worrying about failure for nearly a year, I decided to just go ahead and do it with faith and courage. My lenses were so opaque that not only was it nasty, but was starting to become a driving hazard. I researched heavily on the matter for a long time, yet no posts were found on the net. So i had to prepare myself before executing this task.
Btw, I tried to restore the headlights on multiple occasions, but the plastic was damaged through and through, and nothing improved.
The job took me approx 8 hours, mainly because i was walking back and forth to my tool box, and was extremely cautious during the separation and replacement phases. It was a pain in the behind but well worth it. I did sacrifice some quality time with the wife, and therefore, she held a grudge against my 6 until i lent her the car for a day - she's at peace with it now.
In a nutshell:
1 - I bought the lenses online
2 - I used a heat gun (black and decker), not the oven technique
3 - I sealed the units with black rtv automotive silicone (Permatex)
I bought the lenses at oemxenonshop for $120.00 shipped to Canada. It was a simple matter of emailing the contact with the car details, and voila, 2 weeks later they were in my possession. They hibernated in my basement for nearly a year.
I decided to use a heat gun instead of the oven because A) they didn't fit in the oven B) I don't want to mess around with the removal of the wiring C) I don't want toxic fumes in the house.
Very simply:
1) I secured the unit to the table with zip ties / tie wraps, lens facing sky.
2) I removed the retaining clips
3) I ran the heat gun across the entire seam over and over gradually for 5 minutes approx
4) With a long flathead resting on the edge of the lens, I started pushing upwards while still running the heat gun along the side seams of the lens.
5) As it started to separate, i kept pushing and heating the adhesive until the lens was completely loose.
* I had to be careful as the stretched glue was going to fall onto the insides parts. I used my fingers to pull that away.
6) Dismantled the parts secured to the removed lens, and refit them back onto the new lens.
7) Removed the old gunk from the base of the unit and applied the fresh silicone in the groove. I didn't remove all of the old adhesive, but as much as possible. Flattened the adhesive in the groove by sliding a flathead in the groove at the end.
8) Inserted the new lens and pressed in a bit. Then distributed the excess silicone back into the gaps that needed some to complete the seal. Re-attached the clips.
9) Back on the 6, then big grin with beer in hand.
* I discovered that alcohol safely removed very easily some silicone smears on the lights and body of car.
Without further ado, here are some pictures. Good luck and enjoy!
ID:	209465   Click image for larger version
ID:	209473   Click image for larger version
ID:	209481   Click image for larger version
ID:	209489   Click image for larger version
ID:	209505   Click image for larger version
ID:	209513   Click image for larger version
ID:	209521   Click image for larger version
ID:	209529   Click image for larger version
DrFeelGood likes this.
Mazda SITH
Vader6 is offline
The Following User Says Thank You to Vader6 For This Useful Post:
Mazda6SR (06-12-2018)
post #2 of 12 (permalink) Old 08-25-2017, 02:57 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2677 Post(s)
Nice write-up. They looks 100x better! If you have links to the new lenses you bought I'm sure people would appreciate it.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #3 of 12 (permalink) Old 08-25-2017, 03:57 PM Thread Starter
Vader6's Avatar
Hi ByaKuya, and thanks for the kind words! The difference is even more noticeable with the old headlights on the car before the repair. It's as if my 6 got new eye-glasses! Hahaha.
Anyway, as per your request, here is the direct link to the lenses, which also shows other components for sale.
I can't post links at the moment due to account restrictions so you just need to add the "www" at the beginning and the "html" at the end.....and change the DOT to a "." :
oemxenonshopDOTcom/Mazda-6-Xenon-Front-Headlight-Problems-Ballast-Bulb-Igniter-OEM-HID-Replacement
Mazda SITH
Vader6 is offline
post #4 of 12 (permalink) Old 08-25-2017, 04:32 PM
Quoted: 180 Post(s)
Excellent work! I debated doing this as well but after a few rounds with wet sanding and polishing I was able to mostly bring mine back. Bright lights are much safer and it makes your already sharp looking rider even nicer.
Vader6 likes this.
Modifications:
DrFeelGood is offline
post #5 of 12 (permalink) Old 08-25-2017, 04:43 PM Thread Starter
Vader6's Avatar
Thanks so much for the flattering words Dr Feel Good! Big grin on my face. I'm super proud of my 6....can't find a suitable replacement! Just can't find good looking and affordable v6 mtx sedans these days, so I'm keeping this baby. Thx for boosting my pride lol. Cheers
Mazda SITH
Vader6 is offline
post #6 of 12 (permalink) Old 08-25-2017, 05:06 PM
GerryB's Avatar
Quoted: 304 Post(s)
Well done!
Vader6 likes this.
GerryB is online now
post #7 of 12 (permalink) Old 09-01-2017, 09:13 PM Thread Starter
Vader6's Avatar
So far no fogging. I'll update you after a few rain sessions. Man I'm so glad i did them. I encourage anyone to do the replacement...it's worth every effort.
Mazda SITH
Vader6 is offline
post #8 of 12 (permalink) Old 09-03-2017, 02:11 PM
waughoo's Avatar
Quoted: 258 Post(s)
Great to know! I want to put hid optics in my 04 wagon and would need to separate the lenses to do so. It's good to have a solid write up like this.
Vader6 likes this.
Alex
, and
waughoo is offline
post #9 of 12 (permalink) Old 09-03-2017, 07:12 PM
Quoted: 180 Post(s)
I did this conversion in my 04 as well. I went with the DDM slimline kit with 4500k @50w and am completely satisfied. I did not open the cases and am running them in the halogen projectors. I have never been flashed and doing a test with my wife (driving towards each other, she in my car and me in hers) tells me there is no real variation from any other car on the road.
In the parking garage next to a new IS250, Cadillac Escalade or Acura TL I can tell my cut-off is not as clean but I am completely happy given the level of work and investment.
waughoo and Vader6 like this.
Modifications:
post #10 of 12 (permalink) Old 09-05-2017, 09:32 PM Thread Starter
Vader6's Avatar
Thanks very much for the kind words, I'm glad it'll be of use. Good luck mate!
Mazda SITH
Vader6 is offline
