Quoted: 46 Post(s)
This seems to have become a popular thread and it has gotten pretty long. So for quicker access to key modifications, I figured a list of links would be nice. So here ya go:
Adding Lightness (gutting the car) starts here Relocating battery to the trunk V6 Engine Replacement Rollbar, race seats, harnesses Prepping as dedicated track car First track day & blown engine Prepping as dedicated track car Adding lightness to the hood Prepping as dedicated track car Solid subframe bushings Prepping as dedicated track car 09 Fusion motor swap Prepping as dedicated track car Adding mechanical gauges Prepping as dedicated track car Adding front tow ring Prepping as dedicated track car Poly bushings in front control arms; eccentric upper control arm bushings Prepping as dedicated track car ARP wheel studs, new wheel bearings, SPC adjustable ball joints Prepping as dedicated track car Side exit exhaust Prepping as dedicated track car Bilsteins, Eibachs, SS brake lines, adjustable rear swaybar v1.0 Prepping as dedicated track car Brake cooling ducts Prepping as dedicated track car 285/30 on 18x8.5 +50 Prepping as dedicated track car Weigh-in Prepping as dedicated track car DIY Alignment Prepping as dedicated track car Adding more rear camber Prepping as dedicated track car Adjustable rear swaybar v2.0 Prepping as dedicated track car Dyno Pull Ready for the GO or BLOW test? 2nd track report Track Report - 2 days @ VIR Pedal covers Prepping as dedicated track car 3rd track report Track Report - 2 days @ CMP Speed6 brake upgrade Prepping as dedicated track car 275/35 on 18x10 +40 Prepping as dedicated track car Limited slip differential install Prepping as dedicated track car Adjustable rear swaybar v3.0 Prepping as dedicated track car Fender Flares Prepping as dedicated track car It has been over three years since I started a thread, so I figure I’m due. I’m not sure how other people buy cars, but when I buy a car it is with the full knowledge that one day down the road it will be a dedicated track car. So it was, when I bought the ’03 Mazda6 as a daily driver – relegating the SHO to track duty. I still remember walking into the Mazda Dealer in February of 2003 with my race helmet and asking to test drive a 6s with no sunroof so I could check the headroom. ![]() With the exception of the occasional autocross, the 6 has been a daily driver. Well the 6’s day in the sun has finally arrived. The SHO track car is gone and the Mazda6 has been replaced as a daily driver by yet another future track car. We will now prepare the 6 for full-time flogging. Having done this before, I will share a couple lessons learned: 1. You can’t turn a pig into a race car, but you can spend a lot of money building a really fast pig. This was true with the SHO and I expect it to be true with the 6. I don’t expect to run with the Shelbys, M3s and 911s, just to be one of the fastest FWD-4Doors on the road course. 2. Before we spend money on two-piece carbon fiber rotors, double adjustable shocks, UDPs, and coilovers, we need to shed as much weight as possible – making the car less pig-like. So here is the starting point: 2003 Mazda 6s, 5-speed, 190k Miles Mods: 2006 engine – 70k miles Long tube headers CAI Lightweight Flywheel Kevlar clutch Battery in trunk Not a bad start. Current Weight analysis – 1/4 tank of gas, no driver: Total weight: 3160lbs Front weight: 58.6% Left weight: 50.5% Cross weight: 48.9% The total weight looks to be about a hundred pounds below the published curb weight - I attribute that to the elimination of the cast iron manifolds, pre-cats and the light flywheel. I’m surprised the left and cross weights are so close to 50% - I’m sure moving the battery from the left front to the right rear had a significant impact. Goal – including driver: Total weight: As little as possible - hopefully under 2500lbs Front weight: 50% Left weight: 50% Cross weight: 50% I say “Goal” as an ideal target – we will not likely achieve. FWD cars are always weight biased to the front and most of the weight we shed will be behind the front wheels. We might be able to hit the 50% L/R goal by moving some weight around. Cross weights will change as we shed lbs, but afterwards they can only be adjusted with coilovers. Let the stripping begin! If you are in need of any interior parts (or anything else you see come off the car), shoot me a PM and I’ll get you a price. I plan to sell or Ebay as much as I can to fund my habit. ![]() ![]() Here’s what is coming out: Trunk liners Seats Console Carpet & pad Headliner Trim Radio Speakers Dash Airbags Door panels Window motors Glass (except windshield) Trunk lid reinforcing (keep the skin) Trunk hinges Rear doors and hinges (except skins) Exhaust (behind headers) Sound deadening Heat shields A/C compressor, evaporator, accumulator Bumper bars (keep bumper covers) Hood reinforcing Front fender reinforcing After it is striped, we’ll weigh again before adding the roll cage, fire suppression, transponder, race seats, harnesses, etc. I’ll post pics along the way for your viewing pleasure.
2003 Mazda 6s MTX Mods - Yeah, I got some. ![]() My Threads: DIY Engine Replacement Track Car Prep My YouTube Channel for in-car track videos: http://www.youtube.com/user/canyonry...ow=grid&view=0 Last edited by CanyonRider; 03-20-2013 at 09:18 AM. |
| Sponsored Links | |||
Advertisement | |||
not including the cage, you might be able to get into the 2600# range, but even that will be tough i'd imagine. With rear seats out, 1/4 tank on my 6i i was barely under 3k# from what i remember.
blast on the track, you won't be disappointed!!
Quoted: 46 Post(s)
Still shedding weight
2003 Mazda 6s MTX Mods - Yeah, I got some. ![]() My Threads: DIY Engine Replacement Track Car Prep My YouTube Channel for in-car track videos: http://www.youtube.com/user/canyonry...ow=grid&view=0 |
its sooo empty lol so what did u replace the 6 with for ur dd?
hey, you left the steering wheel. That must be another 3 lbs right there
I laughed when I saw your goal of 2500lbs in your original post. Needless to say, I am no longer laughing. Looks like there's less than 15-20lbs of removable interior left in the whole car. Good luck with your build. Looks like it's coming along great so far.
#7 (permalink) |
Quoted: 182 Post(s)
Dam, nice work dude. I spy a passenger side vent still standing
2004 Mazda 6 Sport V6 MTX-Steel Grey MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18 Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils |
#8 (permalink) |
Groaned at 16 Times in 13 Posts
God I am so jealous!
Greg 2004 Champagne 6s 5spd Sport w/Bose...stock, for now. |
#9 (permalink) |
Quoted: 46 Post(s)
| The Following 2 Users Say Thank You to CanyonRider For This Useful Post: | ashleys6 (07-29-2011), Lvn4him007 (08-08-2011) |
#10 (permalink) |
dayum nice upgrade
(i do love my 6....but thats just hott)
Advertisement | |
