Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Dyno & Track
Old 08-21-2009, 01:44 PM   #1 (permalink)
So I hit up pacific raceway yesterday for my 1st time draggin the car. Needless to say harder than most people perceive it to be, or claim it is.
was sweating balls, was bout 90 degrees.. ill post a slip later but for now I will just write it out
R/T : .502 (which i didnt care about)
60' : 1.916
330 : 5.715
1/8 : 8.887 @ 77.68
1000: 11.582
1/4 : 13.835 @ 100.70
I couldnt get that launch down ... the other times were all 13.9's or low 14's if I truly messed up.
dooser is offline   Reply With Quote
Old 08-22-2009, 07:37 PM   #2 (permalink)
ttshark's Avatar
Nice man! This is a Mazdaspeed right?
Write up a Sig so we know your car specs
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression
Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob
Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel
Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune
ttshark is online now   Reply With Quote
Old 08-22-2009, 09:30 PM   #3 (permalink)
MrTea's Avatar
definately a sig and maybe location in your profile, as i'm sure others might be down to hit up local drag events with you too.
Old 08-23-2009, 01:55 PM   #4 (permalink)
6er
QUOTE (ttshark @ Aug 22 2009, 06:37 PM)
Write up a Sig so we know your car specs[/b]
I'd say it's a speed6.....nothing out for the new V6 that could get it that fast
The Xbox 360, however, has set out to put all previous console gremlins to shame. Among the many 360s in IGN offices and homes the failure rate has been staggering and the replacement process long and aggravating.
- IGN, April 28, 2006
2009 Mazda 6s Touring - Onyx
2009 Toyota Corolla S - Classic Silver Metallic (Wife's Car)
6er is offline   Reply With Quote
