Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Dyno & Track
Old 03-07-2009, 06:27 PM   #1 (permalink)
Send a message via AIM to sp33dy6
i went to english town today for STREET WARS and i came back a very disaponted individual, i own a speed6 bone stock.. i ran a hoorible 14.7 !!
1) launch was off
2) 3rd gear was acting up
3) i was nervous as shittt!!!
any advice?
ko4 2 GT3076
BIG POWAAA
sp33dy6 is offline   Reply With Quote
Old 03-07-2009, 06:44 PM   #2 (permalink)
jmhinkle's Avatar
At least that makes me feel better about turning 14.6's at 5300 ft on a stock car.
Suggestions....WOTBOX but only use the shifting portion unless you have a bolted diff and upgraded axle. RELAX!!!! I have the same problem of getting overly nervous when I get to the line and I miss a gear or launch horribly.
Yup, my car is stock.
jmhinkle is offline   Reply With Quote
Old 03-07-2009, 08:35 PM   #3 (permalink)
lmaoo, the speed6 is one fukd up bitch, but a sexxi bitch nun the less. i think im gonna do wot box. but then again i think ill stick to the natrual shift pattern. i know i can pull a high 13 or low 12 with the proper launch.
ko4 2 GT3076
BIG POWAAA
Old 03-07-2009, 09:43 PM   #4 (permalink)
mmarfan's Avatar
Phhh, using "assistance" (WOT Box) takes all the fun out of it. Just read the tips at the top of the drag forum. (bottom of my sig)
mmarfan is offline   Reply With Quote
Old 03-08-2009, 01:27 AM   #5 (permalink)
jmhinkle's Avatar
The first post, by you at that, had two major flaws in it.
1) reving your engine between 3000 and 5500 does not build boost. You have to have a load on the engine to build boost. Free revving while sitting at the line doesn't do it. Wotbox cuts spark intermittently which creates a load and builds boost for the launch.
2) That loud clunk you hear is NOT the clutchpack engaging. It is the diff smacking the belly of the car. You won't hear that clunk when you have your diff bolted. Also, you should have DSC off which has the clutchpack engaged.
It's quite frightening that you have those two statements in the Speed section of how to launch.
Old 03-08-2009, 09:15 AM   #6 (permalink)
so wadu recomend i do next time around?
ko4 2 GT3076
BIG POWAAA
Old 03-08-2009, 09:42 AM   #7 (permalink)
jmhinkle's Avatar
Do you have your diff bolted?
Old 03-08-2009, 10:08 AM   #8 (permalink)
cm-jp1's Avatar
let me know when u go again.. Ill show you how
2006 speed 6 Titanium Gray
//AP stage 2 93 FMIC v101e //Su race pipe//Cp-e single exit exhaust<span style="color:#696969">//<span style="color:#000000">Cobb SRI//</span>Custom FMIC//HKS ssqv</span>//TWM Stge 2 SS//Su rear motor mount//TT front engine mount//Denso Iridium ITV22//Pro Sport Boost Gauge
1/4- 13.017@104
cm-jp1 is offline   Reply With Quote
Old 03-08-2009, 02:25 PM   #9 (permalink)
my diff is stock as they come and so is my car lol. i will be goin in a few months again not sure mybe earlier depending on the event at hand
ko4 2 GT3076
BIG POWAAA
Old 03-08-2009, 02:29 PM   #10 (permalink)
I've heard the WOTBox is a cat killah.
this is my MAZDAGREMLYN sig.
xtmesisx is offline   Reply With Quote
