Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Dyno & Track
Old 02-02-2009, 04:39 PM   #1 (permalink)
wh1te0nr1ce's Avatar
Send a message via AIM to wh1te0nr1ce
this is with cpe cai and sls 3"tp
i was expecting more....
**2006 Mazdaspeed6 Sport Titanium Gray Metallic**
Greddy TT - Prosport Boost Gauge - CP-E CAI - SLS 3" TP - Turbosmart BOV - 225/45/18 Falken Ziex 912 - ETS 3.5" TMIC
Magnaflow Catback Exhaust - Megan Racing H-Brace - Optima Red Top Battery - SPC Ball Joints
TWM Performance Stage 2 Short Shifter w/ Bushings - Whiteline Adjustable RSB - H&R Sport Springs
Graphite Painted RX-8 Wheels - Cobb AP Stage 2
wh1te0nr1ce is offline   Reply With Quote
Old 02-02-2009, 04:47 PM   #2 (permalink)
Groaned at 2 Times in 1 Post
Don't beat yourself up. Dyno's are only useful for tuning and comparing power changes from mod to mod after getting a baseline. Don't look at "217" and compare it to a completely different dyno that hit 250 stock. If you want to get technical about it, a stock MS6 is supposed to put down 274hp at the crank, which after AWD drivetrain loss is ~213awhp, and then you're in the right ball park.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, SU Boost and Recirc Tubes, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1 w/Bushings, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, CX-7 Antenna, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3, GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler.
Spare GT2871r for sale.
smoker6 is offline   Reply With Quote
Old 02-02-2009, 06:06 PM   #4 (permalink)
yoichi's Avatar
Dyno Dynamics known to be a Heart Breaker Dyno. Do not be dissapointed as ALL dynos read differently and it should only be used as a tuning tool. Use this Dyno as a base now on modifying your car. The Real way to measure power is your trap speed on the track.
After countless hours on the dyno with my previous cars, 217 on a DD sounds about right for AWD and 274 Crank HP. It should read high 230's on a dynojet.
Speculating what all dynos read is pointless though.
Good luck.
Built Motor
344/356
yoichi is offline   Reply With Quote
Old 02-02-2009, 08:12 PM   #5 (permalink)
dan3381's Avatar
Send a message via AIM to dan3381
how can you measure HP by trap speed?
06 mazdaspeed 6 GT velocity red mica Going to a new home.
Replaced by a 07 Dodge Ram HEMI/Laramie
dan3381 is offline   Reply With Quote
Old 02-03-2009, 09:18 PM   #6 (permalink)
mmarfan's Avatar
The higher you trap, the more power you have:
A car that runs a 14.0 @ 102MPH has a lot more power then something that does a 14.0 @ 97MPH
Basic rule of thumb, for every 1 mph you have to gain 10HP. So if you go to the track and run 2MPH quicker then before, you have gained about 20HP.
mmarfan is offline   Reply With Quote
Old 02-03-2009, 11:17 PM   #7 (permalink)
amp
amp's Avatar
QUOTE (mmarfan @ Feb 3 2009, 09:18 PM)
....Basic rule of thumb, for every 1 mph you have to gain 10HP. So if you go to the track and run 2MPH quicker then before, you have gained about 20HP.[/b]
not a good rule of thumb to follow imho.. as there are a great deal number of factors that comes to play with that new found trap speed.....
amp is offline   Reply With Quote
