Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Dyno & Track
Old 01-20-2009, 02:20 PM   #1 (permalink)
Send a message via Yahoo to josh04m6
I want to dyno my 2007 Mazda Speed 6 but there is not anywhere in my state that has a AWD dyno. Is it possible to convert the car to front wheel drive so It can be put on a regular 2 wheel Dyno Jet??
I searched the forums but I did not find what I was looking for. Please help!!!
Thanks
2004 M6i ATX, Intake, Exhaust, NGK Iridium Plugs
josh04m6 is offline   Reply With Quote
Old 01-20-2009, 02:25 PM   #2 (permalink)
jd42's Avatar
QUOTE (josh04m6 @ Jan 20 2009, 02:20 PM)
I want to dyno my 2007 Mazda Speed 6 but there is not anywhere in my state that has a AWD dyno. Is it possible to convert the car to front wheel drive so It can be put on a regular 2 wheel Dyno Jet??[/b]
Lifting the parking brake lever disengages the rear clutch pack, but I don't think I'd want to rely on this for a dyno run. What if the mechanism suddenly engages for some reason during a run? Yikes!
Probably your best bet would be to physically disconnect the rear drive shaft.
Of course, such a setup wouldn't be very accurate for measuring absolute power delivery at the wheels. I guess you could do some basic engine tuning.
Old 01-20-2009, 02:27 PM   #3 (permalink)
knyghtryda's Avatar
QUOTE (josh04m6 @ Jan 20 2009, 11:20 AM)
Thanks[/b]
short answer.... probably.
Long answer... you can disconnect the rear clutch electronically somehow, and that'll stop power going to the rear. You can also pull the handbrake, which should tell the sensor to do the same thing. My question to you is why, and what do you hope to glean from this experiment?
2007 Liquid Platinum Mazdaspeed 6
Currently Installed: Sharkfin | Forge BPV | TWM Stage 2 SS | Dashhawk | COBB Accessport Stage 1+ | Speedie's inlet pipe | Cobb SRI | Magnaflow Exhaust | H&R Springs | Bilstein HD Shocks | SPC Adjustable Balljoints | Cobb Shifter Weight | RX-8 Wheels w/ 225/40-18 Goodyear GS-D3 Tires
Selling: Fujita CAI, DSM 1G BOV
Future Possibilities: who knows...
knyghtryda is offline   Reply With Quote
Old 01-20-2009, 02:38 PM   #4 (permalink)
QUOTE (knyghtryda @ Jan 20 2009, 11:27 AM)
Long answer... you can disconnect the rear clutch electronically somehow, and that'll stop power going to the rear. You can also pull the handbrake, which should tell the sensor to do the same thing. My question to you is why, and what do you hope to glean from this experiment?[/b]
You mean dyno numbers. I'm doing it for a tuning session. I really only want answers from people who actually knows what works and what doesn't.
I am doing basic mods and I would like to have a before and after dyno chart. I don't just want to guess how much of a gain I am getting with the addition of the modifications and tuning.
Old 01-20-2009, 05:51 PM   #5 (permalink)
b12sentra's Avatar
If you are only doing moderate modifications then I dont' know that it's worth alot of trouble to find one once you figure in the cost of the test and everything.
Would a DashHawk work out good enough to help?
'06 Speed6 RPM Street springs, TWM S.S.&bushings, Cobb Tpi, ETS 3.25, 19's w/Bridgestone RE960's, SU BOV, Mazdaspeed CAI, Corksport tower brace, JDM tails, SPC ball joints, SU engine mount, Turbo XS Race Pipe, Technafit brake lines, full syn., Prosport bst ga., shark fin.
The difference between stupidity and genius is that genius has its limits.
b12sentra is offline   Reply With Quote
Old 01-20-2009, 05:55 PM   #6 (permalink)
Groaned at 2 Times in 1 Post
Trying to tune an AWD vehicle on a FWD dyno can't be good. The ebrake bit shouldn't work. IIRC you have to be in motion to disconnect the rear diff with the ebrake (it reengages then if you brake hard for example), and you can't really pull the ebrake in motion on the FWD dyno. lol If we had electronic control of the rear diff that'd be cool, but we don't.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, SU Boost and Recirc Tubes, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1 w/Bushings, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, CX-7 Antenna, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3, GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler.
Spare GT2871r for sale.
smoker6 is offline   Reply With Quote
Old 01-21-2009, 12:03 PM   #7 (permalink)
MS6 P.C.'s Avatar
There is a member here who claims he dynoed his on 2-wd dyno. Cant recall exactly who, but I will search around for him. Theres also a box (cant remeber if its under the dash or the seat) but its the box for our AWD.
gone.
MS6 P.C. is offline   Reply With Quote
Old 01-21-2009, 02:57 PM   #8 (permalink)
Mazspd6,
Maybe its not worth the trouble to you , but it is to me.
Smoker6,
Are you just assuming it isn't good? DSM owners have been converting their awd cars to fwd for years and strapping them on dynos. I don't think Mazda would let the car go into FWD mode with the ebrake trick if it was harmful to the car.
Old 01-21-2009, 04:03 PM   #9 (permalink)
I have absolutely no useful opinion on whether it's ok or not to tune an AWD car in FWD mode. I simply know nothing about it, and thus what I wrote on that was intended to be nothing more than speculative rubbish. lol As to the ebrake trick, what I meant is that the guy that figured it out in detail and hooked up a switch said AWD reengages if you brake hard, and sometimes even randomly after a certain period of time. My point was thus only that it seems it might throw off your results.
Cliff notes: Ignore the bit about FWD tuning, IDK anything about it. Do you think you'll get consistently accurate results with the ebrake pulled to disengage the rear diff if, from what I've read, the car may reengage it without you wanting it to?
Old 01-22-2009, 05:15 PM   #10 (permalink)
MS6 P.C.'s Avatar
PM freekwonder(sp?), He is the one that dynoed on 2wd dyno. Give us details or unless he wants to add anything
gone.
