I did the course wrong the first 5 times
Best run was 0:53, I would have been competitive in the 0:50 range. A 2003ish BMW 325i cranked out a 0:51, I road with hime and it very different, very smooth when transistioning through the slalom, vs the MS6's lurching. Any Critues? I need to work on being more fluid with the throttle for sure, and I was braking too early... http://www.youtube.com/watch?v=piQVsVwQaV8
2006 Mazdaspeed 6 GT: CPE Intake /// Streetunit Rear Motor Mount /// RX8 Wheels /// Forge BPV /// 3.5" Polished ETS /// SLS Test Pipe /// Dash Hawk Equiped /// Cobb AP |
tires play a huge roll. what r u running? i try not to over drive the car into corners cause that will just fuck up your entry for the next turn and the next one. and tell your camera man dont zoom in that much or use a tripod. way way to much camera shake it makess it unbearable to watch
First off---did you walk the course? If you did, do it more next time. If you didn't...then please do it next time, hehe. I could tell you weren't looking ahead in the video too because you did last second changes or seemed surprised by the next gate since you weren't setting yourself up for the next turn.
This being your first autocross though, just be glad you didn't kill anyone or blow anything up. Usually if I did poorly that's what I try to remember 8D
![]() Now rocking a 91 Miata |
id recommend you throw away your first run at every event. just go slow and get a feel for the course the first time out. it always between walking and driving the course
#5 (permalink) | |
QUOTE (werm9 @ Oct 26 2008, 11:37 AM)
I was the only AWD car that showed up, and the Forge BPV was viewed a bit ricey by most.
#7 (permalink) | |
QUOTE (dynasty_v6 @ Oct 26 2008, 01:05 PM)
You discovered something in your ride in the BMW, that a good autocross driver looks very smooth and in some cases, even slow. Their times at the end of the run tell you that they're actually quite quick. So, what can you do to get better? If you can find a autocross school in your area by all means sign up for it. You'll be surprised how much better your times will get. 2-3 seconds improvement isn't uncommon by the end of the day. This school is sanctioned by a SCCA regions across the country, if there's one coming to your area it' worth your time and money to attend it. Evolution Performance Driving Schools
[b]"There are three easy ways of losing money - racing is the quickest, women the most pleasant, and the Stock Market the most certain."</span> |
#9 (permalink) | |
QUOTE (DennisW @ Oct 26 2008, 01:40 PM)
#10 (permalink) |
Why the "ricey" comments on the Forge BPV? Was it chrome??? Or did they not understand the sound it made?? Just curious.
'06 Black Cherry Mica MS6 GT w/sunroof Engine/drivetrain: Cobb AP (Stg.1 91 v1.02) AEM SRI w/ air straightner, Speedie6's T.I.P, Forge BPV, Denso ITV22 spark plugs, SU Silicon Boost Tubes, silicon recirc. and vac. tubes Saikou Michi OCC w/ 2 PCVs, CP-E Motor Mount, SU Stiff Diff bracket Exterior: Badgeless AE style grill, 18x7.5 Kazera KZ-T Silver Rims, 215/45/18 Hankook V12 Evo Bilstein shocks, AutoEXE Lowdown springs, SPC ball joints, Magnaflow catback, Redline Tuning hood shocks, Interior: Lotek gauge pod w/ ProSport boost, water, volts gauges, TWM stage 2 short shifter w/bushings, Redline short shift boot |
