Trel...your such a dick. haha
2006 Liquid Platinum Mazdaspeed 6 sport- Atp Gt3071R turbo, 18psi, Atp fuel cut defender (one that works), Atp 3in dp, 15% tint, VEI digital boost gauge, Greddy Profec spec II boost controler, Megan racing springs, BFG 225/40/18 KDW2's, powercoated stock wheels 2005 Mazda 6s w/ too many mods to name- SOLD |
If Gay and Lame were at a party and they both got hammered and ended up having unprotected sex, this thread would be their lovechild. I was all excited, then you kicked me in the junk. |
#7 (permalink) |
You are a horrible horrible man and we need to race after you get the flash.
#9 (permalink) |
So far the fastest on the flash is a 13.1@103 by 2nr!!!
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic ![]() ![]()
