#1 (permalink) | |
QUOTE (ATL @ Jul 19 2008, 10:22 AM)
been reading and saw news that p3guys went to the track w/ the new flash. Did I miss a post? crap nevermind http://forum.mazda6club.com/index.php?show...00822&st=20 sorry all
2006 pearl white ms6 gt |
well to address the situation i think my clutch is slipping and if you listen to the video from my launch you can sorta tell. The car was pulling pretty well to the point were i was able to do a 13.6@91 because i had to hit the brakes during braket runs. The car still takes off pretty well but i am at the point were i have a dump the clutch insted of slipping the clutch. I really don't like to dump it that much since my warrantee is gone. Since i have finished putting cherryspeeds clutch in i am going to work on getting myself a clutch. I think if i can get back to slipping the clutch i can a 1.6 60ft. Those times also at the track that day were with all season tires and you can hear them scream like a little girl out the hole!!
As you can see 2nr did a 13.1 and before the flash his best was a 13.4@100 not he is at a 13.1@103!!
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic ![]() ![]()
Charles, you need a new clutch with the wot box and you'd be pulling sick times with that beast!
06 MazdaspeeD 6 Black Mica Cobb SRI-->Speedie6 inlet CPE-Catted Downpipe, PG mani AcessPort, Wot box Forge bov, boost gauge in vent catch can, egr delete, PTP gasket and PNP intake mani SU motor mount, TT front engine mount WTB: rear diff mount & Magnaflow exhaust!! PM me |
