Mazda 6 License Plate LEDs! Several Model Options! Plug & Play Install! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 15 (permalink) Old 09-01-2015, 05:21 PM Thread Starter
Mazda6club.com: Sponsors
Diode Dynamics's Avatar
Quoted: 26 Post(s)
Arrow Mazda 6 License Plate LEDs! Several Model Options! Plug & Play Install!
License plate bulbs are used to illuminate the rear license plate on your Mazda 6. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Mazda 6!
The installation is 100% plug-and-play, just replace your factory bulb.
This is one of the best, easiest modifications you can do to improve how your Mazda 6 looks at night.
HP5 Cool White Installed
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design:
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Mazda 6).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Mazda 6 Sedan License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email contact@diodedynamics.com
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 15 (permalink) Old 09-01-2015, 05:36 PM
Donkey Grundle's Avatar
Quoted: 435 Post(s)
Groans: 22
Have you tested these on a 3rd gen (2014+) ?
Quite the discussion going on over here
License Plate LEDs
Diode Dynamics likes this.
Donkey Grundle is online now
post #3 of 15 (permalink) Old 09-01-2015, 05:41 PM Thread Starter
Quoted: 26 Post(s)
License Plate LEDs
We had a local forum member bring his 2015 to us, but we weren't able to take comparison photos for the license plate location
It's a simple 194-sized bulb replacement, just like the previous model years
We will be updating the listing soon
Thanks for the heads up!
Nick C.
Bluewolf likes this.
post #4 of 15 (permalink) Old 09-18-2015, 08:16 PM
Koki's Avatar
Quoted: 16 Post(s)
Will these fit 2015 Mazda 6 ? On your website it says for 2003-2008.
Thx.
Keep the funk alive...
Koki is offline
The Following User Says Thank You to Koki For This Useful Post:
Diode Dynamics (09-21-2015)
post #5 of 15 (permalink) Old 09-21-2015, 09:12 AM Thread Starter
Quoted: 26 Post(s)
Thx.
We are still in the process of updating the listings to include newer model year fitments (10,000+ listings on the site).
194 bulbs are indeed the most common size for license plate locations and should fit your 2015+ just fine!
Feel free to give us a call for more information: (314) 205-3033
Thank you!
Nick C.
post #6 of 15 (permalink) Old 09-23-2015, 09:43 PM
rjhornsby's Avatar
Quoted: 131 Post(s)
Originally Posted by Diode Dynamics View Post
License plate bulbs are used to illuminate the rear license plate on your vehicle. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
You don't happen to carry this type of bulb for the trunk (interior) of a 2016 M6, do you? Looked on your site and only see through 2013. The '16 stock bulb is extremely dim, and your post made me think there might be a solution.
rjhornsby is offline
post #7 of 15 (permalink) Old 09-24-2015, 08:43 AM Thread Starter
Quoted: 26 Post(s)
We have bulb sizes available for all Mazda 6's, we are still working on updating the site with more model year fitment.
Feel free to email us: contact@diodedynamics.com and we will help you find the best bulbs for your application
Thank you!
Nick C.
post #8 of 15 (permalink) Old 10-10-2016, 11:20 AM
Nice looking color spread for these, to match with other lights
I only use email, not FBook; I'm at
Maynard is offline
The Following User Says Thank You to Maynard For This Useful Post:
Diode Dynamics (10-10-2016)
post #9 of 15 (permalink) Old 10-10-2016, 11:22 AM Thread Starter
Quoted: 26 Post(s)
Thank you, we will have updated comparison photos for the Mazda 6 very soon as well!
Nick C.
post #10 of 15 (permalink) Old 10-10-2016, 12:39 PM Thread Starter
Quoted: 26 Post(s)
New comparison photos have been added!
Thanks,
Nick C.
