Mazda 6 Fog Light LED Bulbs! Comparison Photos Added! Yellow XML2 Added! Plug & Play! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 24 (permalink) Old 09-01-2015, 05:18 PM Thread Starter
Mazda6club.com: Sponsors
Diode Dynamics's Avatar
Quoted: 23 Post(s)
Arrow Mazda 6 Fog Light LED Bulbs! Comparison Photos Added! Yellow XML2 Added! Plug & Play!
5000K XML2 Installed
Diode Dynamics carries LED bulbs for replacement of your fog lights, in all major sizes. They are available in HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1420 lumens. Much brighter than factory. These are bright!
XML2 is available in 3000K Yellow / 4000K / 5000K / 6000K Color Temperatures
6000K Cool White XML2 Installed
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Mazda 6).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Mazda 6 Sedan
Mazda 6 Sedan
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Yellow XML2 Installed
Diode Dynamics is offline
post #2 of 24 (permalink) Old 03-24-2016, 04:04 PM Thread Starter
Quoted: 23 Post(s)
Customer Submitted photo with Yellow XML2 Installed
Nick C.
post #3 of 24 (permalink) Old 04-21-2016, 12:17 AM
Quoted: 12 Post(s)
Do you have green, say between 510nm and 540nm color frequency?
Patrick T. Halpin is offline
post #4 of 24 (permalink) Old 04-21-2016, 10:49 AM Thread Starter
Quoted: 23 Post(s)
We don't offer a single color green LED replacement, but our RGB multicolor bulb can create any color via remote control
Nick C.
post #5 of 24 (permalink) Old 10-10-2016, 01:45 PM Thread Starter
Quoted: 23 Post(s)
New Comparison Photos have been added!
Yellow XML2 Installed!
Nick C.
post #6 of 24 (permalink) Old 01-05-2017, 04:32 PM Thread Starter
Quoted: 23 Post(s)
Questions? Chat with an expert on our site!
Diode Dynamics
post #7 of 24 (permalink) Old 01-10-2017, 11:54 PM Thread Starter
Quoted: 23 Post(s)
Contact@diodedynamics.com
post #8 of 24 (permalink) Old 01-11-2017, 10:23 PM Thread Starter
Quoted: 23 Post(s)
Diode Dynamics is on SnapChat!
Nick C.
post #9 of 24 (permalink) Old 01-12-2017, 05:25 PM Thread Starter
Quoted: 23 Post(s)
PM Responses sent!
Thanks,
Nick C.
post #10 of 24 (permalink) Old 01-20-2017, 01:49 PM Thread Starter
Quoted: 23 Post(s)
