Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Premier Sponsors - This section is for vendors that help support our website. > Custom Performance Engineering
Old 07-02-2008, 07:31 PM   #1 (permalink)
Send a message via AIM to Rperea Send a message via Yahoo to Rperea
I have had a ATP 3in turbo DP for a while sitting in my garage its brand new (never been used) But now I want to upgrade to the GT3071r turbo. I found one it self for $700.00 and the kit its $2225.00 +shipping. The Turbo upgrade kit comes with the DP and a short ram intake. But I already have the Intake and the ATP 3in DP. So I need someone's help to tell me if the DP that I already have fits the bolt on ATP Gt3071r turbo upgrade? that way I don't have to buy the whole kit and save my self $1,000.00
Thanks for ya'll help
Randy P
Rperea is offline   Reply With Quote
Old 07-03-2008, 10:49 AM   #2 (permalink)
kore2000's Avatar
QUOTE (Black-Speed-6 @ Jul 2 2008, 06:31 PM)
Randy P[/b]
I think you might be in the wrong section but to answer your question, yes if the DPs are the same then it should bolt up. You would want to contact ATP for confirmation though, not CP-E.
kore2000 is offline   Reply With Quote
Old 07-03-2008, 11:46 AM   #3 (permalink)
FORZDA 1's Avatar
QUOTE (Black-Speed-6 @ Jul 2 2008, 07:31 PM)
Randy P[/b]
Yes, the DP connects to the 3071 via the V-band clamp. You'll be fine and not need the OEM turbo adapter flange that came with the DP.
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now...
Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
FORZDA 1 is offline   Reply With Quote
Old 07-03-2008, 02:12 PM   #4 (permalink)
You can get the turbine housing from ATP for the 3071 that fits the stock Dp if you dont have the Vband set up and then it should bolt right up. i will find out if there is any other things to look out for as i will be installing a GT2871 and Gt3071 between this saturday and next.
CPE catless DP// CPE catback//CPE standback// SRI// ETS top mount// megan springs// turbine tech diff mount//carrilo rods//cp pistons bored .20 over//cometic head gasket/ arp head studs// carrilo crank bolts// balance shaft delete// ported turbine housing// 4" surge compressor housing//port polished bowl port 3 angle valve job// porting intake // 3' inlet and intake// custom FMIC// koni yellow adj ft and rr// SU MM//tial external wastegate 38mm// PG manifold//spec 2+ clutch and stock flywheel// previous info current weight 3410lbs// 260hp 284tq// best qtr. 13.2@103// RECORD BEST 60ft 1.71 Co-Owner and head mechanic
charles is offline   Reply With Quote
Old 07-03-2008, 11:44 PM   #5 (permalink)
QUOTE (FORZDA 1 @ Jul 3 2008, 07:46 AM)
Yes, the DP connects to the 3071 via the V-band clamp. You'll be fine and not need the OEM turbo adapter flange that came with the DP.[/b]
So I would need to get the V-band clamp to make it fit toguether? I'm sorry it may be really stupid question but what is it?
QUOTE (charles @ Jul 3 2008, 10:12 AM)
You can get the turbine housing from ATP for the 3071 that fits the stock Dp if you dont have the Vband set up and then it should bolt right up. i will find out if there is any other things to look out for as i will be installing a GT2871 and Gt3071 between this saturday and next.[/b]
Where can I get the Vband from?
Old 07-05-2008, 12:42 PM   #6 (permalink)
Does anyone know where I can get the Vband from?
Old 07-06-2008, 04:03 AM   #7 (permalink)
ATL
ATL's Avatar
Send a message via AIM to ATL Send a message via MSN to ATL Send a message via Yahoo to ATL
Post
QUOTE (Black-Speed-6 @ Jul 5 2008, 12:42 PM)
Does anyone know where I can get the Vband from?[/b]
www.atpturbo.com
Black CP-E CAI/Black HKS BOV/TurboXS RP/RX-8 Wheels/MS6 Coming soon... LOL
ATL is offline   Reply With Quote
Old 07-06-2008, 12:07 PM   #8 (permalink)
QUOTE (ATL @ Jul 6 2008, 01:03 AM)
www.atpturbo.com[/b]
Thanks ATL
Old 07-08-2008, 05:09 PM   #9 (permalink)
Randy P[/b]
Just out of curiosity, where did you find a GT3071R for only $700? That is less that half the price of any I've seen.
garb1013 is offline   Reply With Quote
Old 07-10-2008, 09:42 PM   #10 (permalink)
QUOTE (garb1013 @ Jul 8 2008, 02:09 PM)
Just out of curiosity, where did you find a GT3071R for only $700? That is less that half the price of any I've seen.[/b]
it was just the turbo it self with anything else... E-bay
