Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Premier Sponsors - This section is for vendors that help support our website. > Custom Performance Engineering
Old 04-17-2008, 04:34 PM   #1 (permalink)
Thumbs up
I know you guys have dirty nasty hp hiding all around that shop of yours. When are we going to see some high rpm turbo grind cams for the MZR?
Scootter.
White Water Pearl MazdaSpeed 6
y2kc0wb0y is offline   Reply With Quote
Old 04-18-2008, 12:24 PM   #2 (permalink)
Probably when they figure out how to control the throttle plate and keep it from closing at higher rpms. Also, probably waiting on final proof and testing that the CDFP provides plenty of fuel for it too.
2006 Mazdaspeed6 GT - Black Mica/Black w/ sunroof & navigation
Mods - Cobb AP, Synapse BPV, cp-e MS6 Nano, cp-e FMIC, cp-e Turbo Inlet, cp-e Dual Catback Exhaust, TXS Test Pipe, Denso 1 step colder plugs, SU Rear Motor Mount, AWR 88 Duro Passenger Motor Mount, AWR 70 Duro Transmission Mount, RP 5w30 Oil, Amsoil Trans, Diff, & PTO Fluids, TWM Stage 1 Short Shifter & Bushings, Cobb Shifter Weight, VG Shark-fin Antenna, Smoked LED Side Markers, Mazdaspeed Oil Cap, MSD DashHawk, RPM Sport Springs, 225/45/18 Goodyear Eagle F1 All-Seasons
shadesofgray19 is offline   Reply With Quote
Old 04-18-2008, 12:29 PM   #3 (permalink)
VirtualMirage's Avatar
I've been to their shop several times, and I think I can confidently say that cams are probably something they won't be doing. I'm not saying this to question their engineering know-how, in this department I think they would be very capable. The reason I don't think it will happen is mainly due to the specialty tools and machines needed to do cams. I think that would best be left to the cam specialists, like Crower and the likes.
...But I could always be wrong.
Paul
2007 Mazda6s GT 5-Door, Tungsten Grey (Auto, 6-speed) : >>> My Garage <<<
1/4 Mile: 15.609s @ 89.69 MPH <-- MIR, 3/1/08. Burnout done for traction, Brake torqued around 1700RPMs, Wheelspin off the line. Low trap time due to Cyl #6 misfire.
0-60 MPH (60.3 actually): 6.45s <-- Timed with MSD DashHawk (TCS off, D Mode, no brake torque, some wheelspin off the line). Repeatable. Time should improve with better launching and better tires.
Dyno/Tune (Conservative timing adjustment) 1/26/08 ---> 182.53 HP / 172.33 TQ at the wheels (SAE format)
VirtualMirage is offline   Reply With Quote
Old 04-25-2008, 04:54 PM   #4 (permalink)
www.cp-e.com's Avatar
Scootter.[/b]
Scott, I love that you included a slef-portrait in your avatar! That's a great picture of you!
Paul[/b]
Yep, as Paul said you need some pretty serious machines in order to cut and grind cams. We'd love to, but we just ain't got the money :P
Paula A Ibey
www.cp-e.com
www.cp-e.com is offline   Reply With Quote
